cable shifter |
cable shifter |
quadracerx |
Nov 24 2012, 09:09 AM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Ok...so I did a search and couldnt find alot of info about using a cable shifter? Im working again on the V8 Car and would prefer a cable shifter. Anyone make a kit? or anyone know exactly what it would take?
Ive looked at Boxster and the MR2 as the actual shifter, but am confused as to how to design the transaxle end? Anyone have links to anything that might help? Thanks, Steve |
Mike Bellis |
Nov 24 2012, 10:51 AM
quadracerx |
Nov 24 2012, 10:54 AM
Been looking at the cableshift.com shifter but couldnt find a photo of the actual shifter? How high does it raise the shifter? Is there a way to modify the stock console to work?
Mike Bellis |
Nov 24 2012, 11:04 AM
The shifter is on cables. You could raise or lower it to fit your needs. In most cases, it bolts to the transmission tunnel. The transmission console must get modified for the cable to pass through. If you are handy, you could make your own but it will take a little R&D on your part. I made one with a Fiero shifter. It worked pretty well but if I were to do it again, I would buy the cable shift kit. For my current build, I'm using a Boxster shifter...
Nov 24 2012, 01:29 PM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I know McMark was working on a solution/kit for the 901 at some point. I don't know how far he got with it.
He *will* be doing a cable shifter setup for a 915 pretty soon. Because i'm going to pay him to do so. (IMG:style_emoticons/default/biggrin.gif) |
quadracerx |
Nov 24 2012, 02:26 PM
I wish McMark would chime in here....LOL
kevin311 |
Nov 24 2012, 02:43 PM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
I built a cable shifter for my tail shift trans and couldn't be happier. I don't think a side shift is hugely different. It completely changes the way the car drives.
Here is a link to my build, it has some vids showing linkage and driving. http://www.914world.com/bbs2/index.php?showtopic=151764 Please let me know if I can help at all. This was my favorite project I have done on my car. Kevin |
Dinobx |
Feb 10 2013, 09:38 PM
Newbie Group: Members Posts: 44 Joined: 15-August 05 From: Toronto, Ontario Member No.: 4,592 |
Hey SirAndy,
I was wondering if your buddy McMark is making any progress on his cable shifter for the 915. I'm beginning to research a shifter solution myself. I have a buddy of mine (engineer), that I'm talking with about maybe using a master and slave hydraulic solution. Is McMark's handle McMark? Thanks. Dino I know McMark was working on a solution/kit for the 901 at some point. I don't know how far he got with it. He *will* be doing a cable shifter setup for a 915 pretty soon. Because i'm going to pay him to do so. (IMG:style_emoticons/default/biggrin.gif) |
Feb 11 2013, 01:09 AM
Is McMark's handle McMark? Yes, that's his user name. And no, no progress as of yet, which is 100% my fault and not Mark's. (IMG:style_emoticons/default/dry.gif) |
Mikey914 |
Feb 11 2013, 11:32 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sweet set up.
tscrihfield |
Feb 11 2013, 05:16 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
I am just finishing up my cable shift setup. It utilizes a boxster shifter. I do not like the cableshift setup due to the cable having to wrap around the trans especially if you want to run exhaust back there....
If you'd like you can check mine out as well. Unfortunately it won't be in the car for a couple months as I am finishing the interior first. I have a friend who is also using the design I came up with and his will be installed In a couple weeks. Thomas |
Mike Bellis |
Feb 11 2013, 06:03 PM
Just buy one from www.cableshift.com
02loftsmoor |
Feb 12 2013, 08:07 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Look at an old Ferio it was a front wheel drive train stuck in the middle, it had cable shift it may give you an Idea
904svo |
Feb 12 2013, 09:26 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I put a Subaru engine in my kit car and could not use cables as there was not enough room to get the cables in. The bends out of the firewall were too sharp
and the cable would not operate properly. So I came up with this arrangement. Which uses the stock shifter |
76-914 |
Aug 7 2013, 02:47 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Wow! Their really nice but out of my CSOB price range. $648 for the Suby model. (IMG:style_emoticons/default/screwy.gif) I didn't check the 901 prices. |
ConeDodger |
Aug 7 2013, 04:59 PM
Apex killer! Group: Members Posts: 23,573 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I know McMark was working on a solution/kit for the 901 at some point. I don't know how far he got with it. He *will* be doing a cable shifter setup for a 915 pretty soon. Because i'm going to pay him to do so. (IMG:style_emoticons/default/biggrin.gif) My new 3.2 will start with my modified 901 while I gather parts to do the 915. (seems I destroyed 2nd, 3rd, a couple sliders and synchros when a chunk of gear broke off on my 915) (IMG:style_emoticons/default/confused24.gif) I think he will be developing the 901 cable shifter on mine... |
Chris H. |
Aug 7 2013, 07:43 PM
Senior Member Group: Members Posts: 4,029 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Why is the cableshift.com Subaru cable coming out straight up vertically like that? Seems like it would interfere with the underside of the trunk floor. Otherwise I might just buy it and be done with it.
jimkelly |
Aug 7 2013, 08:18 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
good question
McMark |
Aug 7 2013, 08:40 PM
I have a design for the internal piece that will fit in the stock location. Just have to get some extra time to work on the transmission end. I know there are a few people who are eager to get this going. Probably wont see anything tangible until near the end of this year.
Somebody find me a couple good employees. (IMG:style_emoticons/default/smile.gif) |
jimkelly |
Dec 26 2013, 08:41 PM
Lo-Fi Version | Time is now: 2nd May 2024 - 05:45 AM |
