83 3.0 SC engine install into a 914, Need some wiring help |
Luke M |
Nov 29 2012, 11:57 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
My brother has a 74 914 2.0 that's going to get a 83 3.0 SC installed into it.
The engine is going to be run with Weber carbs. I know that some members may have a 3.0 installed in their 914's . The question that I have is what type of ignition source are you using? I've heard the 83 distributor cant be used and need to use an earlier one ? Can a MSD 6AL box, & coil be used instead of the cd box? The engine wire harness what's needed to make this work? Any help would be greatly appreciated. Thanks, Luke |
Lo-Fi Version | Time is now: 18th May 2024 - 08:13 AM |
