anyone ever PLATE a-arms or trailing arms ? |
jimkelly |
Dec 2 2012, 12:18 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pic
G e o r g e |
Dec 2 2012, 12:21 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
euro911 |
Dec 2 2012, 01:10 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Those look Sharp (IMG:style_emoticons/default/rolleyes.gif)
Rand |
Dec 2 2012, 01:34 PM
Why?
echocanyons |
Dec 2 2012, 01:36 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I would think powder coating would be a bit more ideal than zinc plating.
Rand |
Dec 2 2012, 01:39 PM
Is this discussion about bling factor? It's not like those parts need extra protection from all the latest technologies to survive. What is the goal??
Rand |
Dec 2 2012, 01:41 PM
Don't stop at zinc. Go for gold.
G e o r g e |
Dec 2 2012, 02:25 PM
jimkelly |
Dec 2 2012, 03:10 PM
i've asked from the standpoint of - not bling - but from why put a on chipable protection that has some added weight, when one could plate?
george - exactly what i was asking : ) is plating about the same cost as powder or paint? |
Rand |
Dec 2 2012, 05:38 PM
i've asked from the standpoint of - not bling - but from why put a on chipable protection that has some added weight, when one could plate? I figured that Jim. (IMG:style_emoticons/default/smile.gif) I just figure when it comes to parts that don't typically have rust issues, paint is the cost-effective solution. |
monkeyboy |
Dec 2 2012, 08:17 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I would probably powder coat it myself, but those look damn good.
Eric_Shea |
Dec 2 2012, 09:33 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We don't do either anymore. Zero-Rust on bare metal then a semi-gloss finish over that. Powder is too thick for brake clips and, the base as the arms fit into the crossbar.
JoeSharp |
Dec 3 2012, 07:39 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Those parts went on Carerror, so far only used as an A/X car. I did it for the weight, zink is lighter than paint.
rwilner |
Dec 3 2012, 10:16 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
We don't do either anymore. Zero-Rust on bare metal then a semi-gloss finish over that. Powder is too thick for brake clips and, the base as the arms fit into the crossbar. +1 I had my A arms powder coated and cleared. I had to sand at least the clear away, being very careful not to expose bare metal, to get the ball joints to seat. Also, getting the sway bar bushings in was hard. Plus -- Powder can't be touched-up if you ever want to, it needs to be blasted and coated all over again. If I had to do it again, I'd get them blasted at a job shop and then paint them in my attic...or maybe take the $$ I would spend getting them powdercoated and buy myself a blast it all! |
Dec 3 2012, 11:47 AM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
We don't do either anymore. Zero-Rust on bare metal then a semi-gloss finish over that. Powder is too thick for brake clips and, the base as the arms fit into the crossbar. +1 I had my A arms powder coated and cleared. I had to sand at least the clear away, being very careful not to expose bare metal, to get the ball joints to seat. Also, getting the sway bar bushings in was hard. Plus -- Powder can't be touched-up if you ever want to, it needs to be blasted and coated all over again. If I had to do it again, I'd get them blasted at a job shop and then paint them in my attic...or maybe take the $$ I would spend getting them powdercoated and buy myself a blast it all! Rich, Feel free to come over and use a large cabinet with a large compressor. You can stand there all day long and have fun. Not my favortie thing to do with my time. I send my stuff out in large batches...it comes back all done. Send junk, get back pretty painted or powder coated stuff. Never thought of plating suspension parts, but now that I see them, its not a bad idea. I wonder if there is a way to plate them black...not so shiny... Rich |
rwilner |
Dec 3 2012, 11:57 AM
I wonder if there is a way to plate them black...not so shiny... There sure is...zinc nickel. It comes back looking like anodized aluminum. We had it done frequently for marine applications at my first job. The cool thing is that it's still electrically conductive, so you can use the coated parts to ground things to engine blocks. [HIJACK] Rich, you should see my garage right now. Suspension and brake parts everywhere. After I work, I have to clear a path so Abbie can get the stroller in and out. [/HIJACK] |
Dec 3 2012, 12:07 PM
I wonder if there is a way to plate them black...not so shiny... There sure is...zinc nickel. It comes back looking like anodized aluminum. We had it done frequently for marine applications at my first job. The cool thing is that it's still electrically conductive, so you can use the coated parts to ground things to engine blocks. [HIJACK] Rich, you should see my garage right now. Suspension and brake parts everywhere. After I work, I have to clear a path so Abbie can get the stroller in and out. [/HIJACK] Box up what you want and bring some or your favorite media and have at it. Its all hooked up, vacuum system, lights and compressor. Again, not my favorite place to stand all day long.... You do know that Home Depot sells big ass plastic shelving units....right? Get some 2*4,s and plywood, build a shelf over the front hood of the car. Put all your shit on there, get it out of the mad angry mom's way. Big ass plywood shelf/floor Built for weight....post under shelf, dont rely on the shear strength of a nail. Then, get the plastic shelves from Home depot and set them up there in half sections. You get about 4 feet of storage...double depth if you do it right. Everything (everything) but the engine can fit on top of a porsche....with proper shelving and roof racks (IMG:style_emoticons/default/smile.gif) If you are an engineer, you can also put the motor above the car...but you need to lift it...and you have room in front of the car for that...so I would not bother. Get her car inside dufus. rich rich |
bshounen |
Apr 16 2014, 08:56 PM
Newbie Group: Members Posts: 16 Joined: 6-February 14 From: vegas Member No.: 16,967 Region Association: None |
on the subject of arms lets talk about mak'n them stronger...
biosurfer1 |
Apr 16 2014, 09:02 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
You do know that Home Depot sells big ass plastic shelving units....right? Get some 2*4,s and plywood, build a shelf over the front hood of the car. Put all your shit on there, get it out of the mad angry mom's way. That is brilliant Rich! I know what I'll be making this weekend. The space above my 914 in the garage is wasted right now (IMG:style_emoticons/default/beer.gif) |
MoveQik |
Apr 17 2014, 06:24 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
You do know that Home Depot sells big ass plastic shelving units....right? Get some 2*4,s and plywood, build a shelf over the front hood of the car. Put all your shit on there, get it out of the mad angry mom's way. That is brilliant Rich! I know what I'll be making this weekend. The space above my 914 in the garage is wasted right now (IMG:style_emoticons/default/beer.gif) Slight hijack...I have a similar solution. I put two of the steel shelving units together so the shelf is 3' deep and the car fits perfectly. (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 06:02 PM |
