anyone ever PLATE a-arms or trailing arms ? |
jimkelly |
Dec 2 2012, 12:18 PM
pic
Attached image(s) |
Eric_Shea |
Dec 2 2012, 09:33 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We don't do either anymore. Zero-Rust on bare metal then a semi-gloss finish over that. Powder is too thick for brake clips and, the base as the arms fit into the crossbar.
rwilner |
Dec 3 2012, 10:16 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
We don't do either anymore. Zero-Rust on bare metal then a semi-gloss finish over that. Powder is too thick for brake clips and, the base as the arms fit into the crossbar. +1 I had my A arms powder coated and cleared. I had to sand at least the clear away, being very careful not to expose bare metal, to get the ball joints to seat. Also, getting the sway bar bushings in was hard. Plus -- Powder can't be touched-up if you ever want to, it needs to be blasted and coated all over again. If I had to do it again, I'd get them blasted at a job shop and then paint them in my attic...or maybe take the $$ I would spend getting them powdercoated and buy myself a blast it all! |
r_towle |
Dec 3 2012, 11:47 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
We don't do either anymore. Zero-Rust on bare metal then a semi-gloss finish over that. Powder is too thick for brake clips and, the base as the arms fit into the crossbar. +1 I had my A arms powder coated and cleared. I had to sand at least the clear away, being very careful not to expose bare metal, to get the ball joints to seat. Also, getting the sway bar bushings in was hard. Plus -- Powder can't be touched-up if you ever want to, it needs to be blasted and coated all over again. If I had to do it again, I'd get them blasted at a job shop and then paint them in my attic...or maybe take the $$ I would spend getting them powdercoated and buy myself a blast it all! Rich, Feel free to come over and use a large cabinet with a large compressor. You can stand there all day long and have fun. Not my favortie thing to do with my time. I send my stuff out in large batches...it comes back all done. Send junk, get back pretty painted or powder coated stuff. Never thought of plating suspension parts, but now that I see them, its not a bad idea. I wonder if there is a way to plate them black...not so shiny... Rich |
rwilner |
Dec 3 2012, 11:57 AM
I wonder if there is a way to plate them black...not so shiny... There sure is...zinc nickel. It comes back looking like anodized aluminum. We had it done frequently for marine applications at my first job. The cool thing is that it's still electrically conductive, so you can use the coated parts to ground things to engine blocks. [HIJACK] Rich, you should see my garage right now. Suspension and brake parts everywhere. After I work, I have to clear a path so Abbie can get the stroller in and out. [/HIJACK] |
r_towle |
Dec 3 2012, 12:07 PM
I wonder if there is a way to plate them black...not so shiny... There sure is...zinc nickel. It comes back looking like anodized aluminum. We had it done frequently for marine applications at my first job. The cool thing is that it's still electrically conductive, so you can use the coated parts to ground things to engine blocks. [HIJACK] Rich, you should see my garage right now. Suspension and brake parts everywhere. After I work, I have to clear a path so Abbie can get the stroller in and out. [/HIJACK] Box up what you want and bring some or your favorite media and have at it. Its all hooked up, vacuum system, lights and compressor. Again, not my favorite place to stand all day long.... You do know that Home Depot sells big ass plastic shelving units....right? Get some 2*4,s and plywood, build a shelf over the front hood of the car. Put all your shit on there, get it out of the mad angry mom's way. Big ass plywood shelf/floor Built for weight....post under shelf, dont rely on the shear strength of a nail. Then, get the plastic shelves from Home depot and set them up there in half sections. You get about 4 feet of storage...double depth if you do it right. Everything (everything) but the engine can fit on top of a porsche....with proper shelving and roof racks (IMG:style_emoticons/default/smile.gif) If you are an engineer, you can also put the motor above the car...but you need to lift it...and you have room in front of the car for that...so I would not bother. Get her car inside dufus. rich rich |
Lo-Fi Version | Time is now: 6th May 2024 - 03:54 AM |
