Diameter of hole in rear valance |
Mhead |
Dec 4 2012, 08:57 AM
Newbie Group: Members Posts: 42 Joined: 3-December 06 From: Ma Member No.: 7,302 |
Does anyone know what the diamter of the hole is in the early style valance? I am restoring an old one and the exisiting hole is a bit rough, want to bring it back to original specs.
Thanks |
nathansnathan |
Dec 4 2012, 01:10 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
Some things to note, there are different hole locations at least, not sure about size, between the 4 and the 6. Also, to mention, it should have a lip on it. These are from a 4. I have one like this at home and could measure later, if no one has the spec before then.
(IMG:http://www.914world.com/bbs2/uploads/post-5765-1291684027.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-5765-1291684051.jpg) |
Mhead |
Dec 4 2012, 01:40 PM
Some things to note, there are different hole locations at least, not sure about size, between the 4 and the 6. Also, to mention, it should have a lip on it. These are from a 4. I have one like this at home and could measure later, if no one has the spec before then. (IMG:http://www.914world.com/bbs2/uploads/post-5765-1291684027.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-5765-1291684051.jpg) This is for a 1970/1.7 ltr...I can wait til you get the chance to measure it. Thanks |
Mhead |
Dec 6 2012, 08:57 AM
nathansnathan |
Dec 6 2012, 09:34 AM
I forgot, sorry, busy day yesterday - I was trying hard to remember to pick up my welder from repair, as I had forgot it the day before, and forgot to remember to check the hole diameter.
I'm a man on a mission typically, trying to get home from work and will forget all else without , well, a post it note on my monitor. (IMG:style_emoticons/default/chair.gif) Later, I got a little flustered trying to get the welder out of my bus - ended up rolling it down 2 8 foot 2x12 's. I had to position the bus the perfect distance from the curb/lip of my overhead door. Took me about an hour to set it up and roll the 300 lb unit down. By the time I got it all set up to test I was late for World of Warcraft which is Wed at 7, and my girlfriend gets pissed. I did run a bead (IMG:style_emoticons/default/welder.gif) and it's fine, thank god. I will make a post it note for my monitor about the diameter of the hole, will definitely remember today if no one else chimes in. |
nathansnathan |
Dec 6 2012, 06:57 PM
Alright, so the hole in the snowplow for my 4 is I would say 3.75 inches (actually measured 3.769) wide. The lip tapers in just a bit, so it is slightly larger than that at the outer, like 3.85, and then goes down to that dimension. It is slightly smaller vertically, at 3.699 inches to be approximately exact at the smaller innermost. (IMG:style_emoticons/default/smile.gif) The hole starts at about a 32nd short of 8 1/4 inches from the outer edge of the left support 'strap' (metal reinforcements on the back). I hope that makes sense...
Lo-Fi Version | Time is now: 21st May 2024 - 08:53 PM |
