Sail Trim Removal, howdya do that? |
type11969 |
Nov 6 2004, 06:22 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
So how do you remove the sail trim? I got the two vertical pieces off no problem, but I can't figure out how to pull the horizontal one off. It slides back and forth in that channel, but it doesn't slide past the flange that the sail is spot welded to. Please let me know how to do this.
Also, above the rear window on the underside of the targa bar there are 6 plastic plugs that pop into what seems to be threaded holes, what are these for? Thanks, Chris |
Lo-Fi Version | Time is now: 25th May 2024 - 12:41 AM |
