> Need info on installing intermittent wiper relays
JeffBowlsby
post Dec 10 2012, 08:43 AM
I understand the wiper relays will work for 1972-76 914s, because these cars have the brown/black wres in the main harness.
Which wiper lever switches will work with this…? I understand that a 924 switch will work. Got part numbers that work with the relay?
914.613.915.14 Stock 72-74 wiper switch?
914.613.915.15 Stock 75-76 wiper switch?
Is there a tab on the wiper switch that needs to be removed for the intermittent function? Where exactly is the tab? Any photos?
TIA
Jeff Bowlsby   Need info on installing intermittent wiper relays   Dec 10 2012, 08:43 AM
SirAndy   I understand the wiper relays will work for 1972-...   Dec 10 2012, 12:11 PM
Eric_Shea   I used the 924 switch on my 74 column. The plug is...   Dec 10 2012, 01:13 PM
Elliot Cannon   I used the 924 switch on my 74 column. The plug i...   Dec 10 2012, 04:58 PM
zig-n-zag   There is an article written in Up-Fixin der Porsch...   Dec 10 2012, 01:29 PM
jim_hoyland   :agree: The 924 switch was the easiest way to go.   Dec 10 2012, 04:38 PM
Garold Shaffer   While the 924 switch will work, it is not the same...   Dec 10 2012, 05:09 PM
rdauenhauer   Doesnt explain Jeffs question, & Andys comment...   Dec 10 2012, 05:34 PM
Garold Shaffer   Doesnt explain Jeffs question, & Andys commen...   Dec 10 2012, 05:39 PM
Jeff Bowlsby   "Trim the tab on the steering column cover wh...   Dec 10 2012, 07:46 PM
914Sixer   Okay, here are the pictures. I just happened to h...   Dec 10 2012, 08:18 PM
Jeff Bowlsby   Thanks Mark, It looks like the steering column co...   Dec 11 2012, 10:51 AM
Eric_Shea   Electric lead for washer pump all in one switch....   Dec 11 2012, 11:52 AM
Eric_Shea   No, it's the switch.   Dec 11 2012, 11:56 AM
Eric_Shea   For Kevin: http://www.914world.com/bbs2/uploads_o...   Dec 11 2012, 12:01 PM
rdauenhauer   Eric are the rubber isolators still available new?...   Dec 11 2012, 02:10 PM
914Sixer   Jeff, The picture is a little off. The angle of c...   Dec 11 2012, 08:24 PM
914Sixer   Isolators are still available, about $8 each....   Dec 11 2012, 08:28 PM
a914622   So with that figured out can the programable delay...   Dec 11 2012, 08:47 PM
914Sixer   Relay part number is for a VW Rabbit.   Dec 11 2012, 08:57 PM
- Lo-Fi Version Time is now: 6th July 2025 - 01:22 AM
