Pushrod tubes with different spacing? Pictures added |
Geezer914 |
Dec 11 2012, 01:43 PM
Geezer914 Group: Members Posts: 1,423 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I have 2 sets of pushrod tubes. Both are the same length and the diameter is the same. The large ends are identical but the small are different. Which are correct?
Attached thumbnail(s) |
Mark Henry |
Dec 11 2012, 02:00 PM
Geezer914 |
Dec 11 2012, 06:45 PM
Picture added
Mark Henry |
Dec 11 2012, 06:52 PM
Still the same OD?
One on the right looks damaged. |
914Sixer |
Dec 11 2012, 10:38 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Mark is correct the 70 model 1.7 had the small head diam. Most of the heads were drilled out by the machine shops when the heads were rebuilt to accept the larger tube. You may have mixed matched heads if they are one the same engine.
Lo-Fi Version | Time is now: 21st May 2024 - 02:07 PM |
