Geezer914
Dec 11 2012, 01:43 PM
Click to view attachmentI have 2 sets of pushrod tubes. Both are the same length and the diameter is the same. The large ends are identical but the small are different. Which are correct?
Mark Henry
Dec 11 2012, 02:00 PM
QUOTE(Geezer914 @ Dec 11 2012, 02:43 PM)
Should be the other way around...early 1.7's had a smaller head side tube end.
Mark Henry
Dec 11 2012, 06:52 PM
Still the same OD?
One on the right looks damaged.
914Sixer
Dec 11 2012, 10:38 PM
Mark is correct the 70 model 1.7 had the small head diam. Most of the heads were drilled out by the machine shops when the heads were rebuilt to accept the larger tube. You may have mixed matched heads if they are one the same engine.
