Fuel tank pressurized ?, how to fix |
jsayre914 |
Dec 12 2012, 05:59 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I have noticed that when I go to fill the tank every time, I turn the gas cap and a LOT of air goes in. It acting like a vacume. I can shut the car off and even a short while later it holds good vacume. This is not normal right.
How to resolve. Thanks |
SLITS |
Dec 12 2012, 06:04 PM
The vent on the filler assembly is plugged? 1/8" cloth pipe that normally goes to the charcoal canister (unless it's '74 and on).
Dec 12 2012, 06:08 PM
The vent on the filler assembly is plugged? 1/8" cloth pipe that normally goes to the charcoal canister (unless it's '74 and on). (IMG:style_emoticons/default/agree.gif) Since i removed the charcoal canister a long time ago, i simply shoved the small vent hose inside the big plastic drain tube. That way, any venting vapors get at least routed under the car ... (IMG:style_emoticons/default/popcorn[1].gif) |
jsayre914 |
Dec 12 2012, 06:13 PM
can you show me in the picture where the clog might be. or the hose to pull off for the quick fix
thanks Attached image(s) |
Dec 12 2012, 06:26 PM
can you show me in the picture where the clog might be. or the hose to pull off for the quick fix You need to remove the expansion tank around the filler neck to see if it's all connected correctly. (IMG:style_emoticons/default/smash.gif) |
Dec 12 2012, 06:27 PM
Are your large tank vent hoses still connected to the engine? I can see both hoses going towards the drivers side from the charcoal canister.
Did you plug them in the engine compartment? (IMG:style_emoticons/default/idea.gif) |
jsayre914 |
Dec 12 2012, 06:38 PM
Are your large tank vent hoses still connected to the engine? I can see both hoses going towards the drivers side from the charcoal canister. Did you plug them in the engine compartment? (IMG:style_emoticons/default/idea.gif) D-jet is all plumbed correctly, they go to a vent hose and the air box I think. |
914itis |
Dec 12 2012, 06:39 PM
Pressure from the woofers . You may notice te same when you open the trunk . (IMG:style_emoticons/default/av-943.gif)
jsayre914 |
Dec 12 2012, 06:43 PM
Pressure from the woofers . You may notice te same when you open the trunk . (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/dry.gif) I know where your car is parked on April 20th |
914itis |
Dec 12 2012, 07:03 PM
Yeah , but by the time you get there, ( joe's 2013 Hershey emergency thread) I ll be up ..
Mike Bellis |
Dec 12 2012, 10:16 PM
SLITS |
Dec 13 2012, 07:51 AM
The vent on the filler assembly is plugged? 1/8" cloth pipe that normally goes to the charcoal canister (unless it's '74 and on). (IMG:style_emoticons/default/agree.gif) Since i removed the charcoal canister a long time ago, i simply shoved the small vent hose inside the big plastic drain tube. That way, any venting vapors get at least routed under the car ... (IMG:style_emoticons/default/popcorn[1].gif) Real Krauts think alike (IMG:style_emoticons/default/biggrin.gif) |
rjames |
Dec 13 2012, 11:25 AM
I'm made of metal Group: Members Posts: 3,934 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Why two speakers and not just one? (IMG:style_emoticons/default/confused24.gif) I doubt your getting much stereo imaging with those under a piece of sheet metal. Mostly likely getting just a bunch of phase cancellation. |
jsayre914 |
Dec 13 2012, 03:21 PM
Why two speakers and not just one? (IMG:style_emoticons/default/confused24.gif) I doubt your getting much stereo imaging with those under a piece of sheet metal. Mostly likely getting just a bunch of phase cancellation. I love 914world. I can hang with lots of ADD friends like me (IMG:style_emoticons/default/wub.gif) But, since we are gonna talk about woofers now. I was running 1 12 inch sub for 2 years, sounded o.k. but as always i was not satisfied. i then found another amp that matched the first one and found a great deal on these Phoenix subs with the dual voice coils. I hired a hippy to paint all the amps to match the car and built a box that would fit like a glove in the front trunk. I removed the heater hoses and the sound passes through the 3 inch holes in the footwell. At higher volume you can feel the air from the holes. Now it sounds freekin awesome (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/chair.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 03:03 PM |
