Pertronix ignitor electronic ignition, Is there a down side?? |
Al Meredith |
Dec 16 2012, 06:29 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have two cars with trotronix. I always cary a spare 009 with the timing preset so I can drop in if needed. Never been nessary
mtndawg |
Mar 7 2013, 09:30 AM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I'm bumping this because I'm thinking about going with electronic ignition...probably pertronix.
Spoke |
Mar 7 2013, 10:11 AM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Pertronix is a good economical way to replace points with electronic switching.
Had them on 2 cars without fail. Nice part is they drop right in with no or minimal fitment issues. I do carry spare points and condenser. |
reharvey |
Mar 7 2013, 10:25 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
I have Pertronix installed on four of my cars without any problems.
JamesM |
Mar 7 2013, 10:48 AM
Senior Member Group: Members Posts: 1,904 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have always found they improve things, even more so if your dizzy is worn. The only downside to the pertroinix that i can think of is that it costs 2x as much as the hotspark which is basically the same thing.
I have had a crane optical pickup fail Never had a petronix fail in 12 years Have a hotspark waiting to be installed in one of my other cars, have not ran it yet. |
kkid |
Mar 7 2013, 11:11 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
don't know about the petronics but have had a hot spark and just found out last week that was failed for a while. It gave me weak sparks thus very bad gas mileage and terrible drive abilities. Almost forgot how to time since it's been 4 years. Hot spark came with 3 yrs warranty. damn!
Chris H. |
Mar 7 2013, 11:16 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I've had a Pertronix in my 1.8 for 10 years. Really smoothed out the idle. The only down side has already been stated...it is electronic and can fail. A spare is cheap insurance for long trips.
Always heard not to leave the key in the "ON" position or it will burn the Pertronix, but I have left mine one accidentally OVERNIGHT and it was fine. Was probably just lucky that the current didn't spike at all because they are susceptible to "releasing the magic smoke". |
scott_in_nh |
Mar 7 2013, 12:02 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I installed the Hot-Spark setup 12,000 miles ago and haven't touched my distributor since.
FWIW you shouldn't leave the key on with points either, so my radio is wired so that it always has power - there is no need to leave the key on to listen to music. I have not seen anybody complain of this unit failing and it is substantially less expensive. |
Dasnowman |
Mar 7 2013, 12:51 PM
You miss 100% of shots you don't take! Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
Hi guys I'm sort of a noobie to this what is the Pertronix are you guys running (part #) and are you using there coil with it I think they make a flamethrower model?
I have a 71 1.7L with a djet I hopefully going to find all the parts for. |
euro911 |
Mar 7 2013, 01:18 PM
Marlon, check their web site to determine which unit you need, it's dependent on the dizzy you're running
Johny Blackstain |
Mar 7 2013, 02:47 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I run the Pertronix in my LE & have had no issues w/ it, however I did research 1st & found that most people who complained of failures did not match the coil to the Pertronix, as per the instructions. So I also got a matching coil for it & installed both @ the same time & have had no issues whatsoever.
Drums66 |
Mar 7 2013, 03:12 PM
[quote name='pt_700' date='Dec 13 2012, 01:16 PM' post='1783359']
i've heard the early ones are prone to fail if one leaves the ignition on w/o the engine running (as in listening to the radio). .....I started using them(pertronix) back in the 90's when this was true!...I think they've worked out that bug, in the new set's? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) .... |
euro911 |
Mar 7 2013, 06:36 PM
It's a good idea to power your radio/stereo system from a fuse-protected connection directly at the battery anyway. Just remember to turn it off when you leave the car.
Wyvern |
Jul 31 2018, 08:20 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Digging up an older thread ... thats what happens when you search ..
I am going to go Pertronix II and coil. '73 1.7 stock dizzy I have found multiple sites with different part #s I have found 91847V (this is on their site) & 91847A (on multiple vendor sites) Any help with the actual part # needed ? |
Wyvern |
Jul 31 2018, 08:30 PM
Digging up an older thread ... thats what happens when you search .. I am going to go Pertronix II and coil. '73 1.7 stock dizzy I have found multiple sites with different part #s I have found 91847V (this is on their site) & 91847A (on multiple vendor sites) Any help with the actual part # needed ? Answered my own question by searching just a bit more Info here to help others 1847V for vaccuum. 1847A for non-vacuum. So "V" it is |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:17 AM |
