> is this the lead for the thero-time switch?, help!
markyb
post Dec 15 2012, 12:00 PM
Just setting up for testing my new timing light an I saw this lead disconnected. I pulled out my trusty Haynes and my guess is that it's the thermo-time lead wire?
Is this supposed to be on the positive terminal of the coil?Attached Image
Krieger
post Dec 15 2012, 12:04 PM
I do not think that is the thermo time. That would be on the base of the plenum.
jimkelly
post Dec 15 2012, 12:12 PM
Delaware USA
bowlsby has links to every harness - 3/4 down page
http://bowlsby.net/914/WiringHarnesses/
markyb
post Dec 15 2012, 12:13 PM
I had a Pertronix installed maybe the old lead to the distributor? I can't trace it since it tucks behind the firewall mat and is wrapped with the factory binding tape. It looks like an inline relay of some sort? I can do a lot of mechanical stuff, but reading the schematic is giving me a bit'o trouble...
markyb
post Dec 15 2012, 12:34 PM
I traced it down and see that it joins up with a second wire fed down through the engine tin. This is an A/C car and it's currently disconnected, judging by the size of the wire and the inline relay, I'll bet it has something to do with that. Thanks for the effort, I thought that I was on to something bigger....if it isn't that, as Arnold would say, I'll be bak!
dlee6204
post Dec 15 2012, 02:55 PM
Howdy
QUOTE(markyb @ Dec 15 2012, 01:34 PM) *
You are correct. It's for the A/C Unit.
markyb
post Dec 15 2012, 06:37 PM
QUOTE(dlee6204 @ Dec 15 2012, 03:55 PM) *
Thanks dlee, at least I won't have to hunt for those wires when I put the a/c back in service next spring! I would suspect that those are the trigger wires for the compressor, I have a bit of research to do this winter on which parts I'll use for the new system, originally a VPC unit. I've been saving up lots of info and suggestions from the "Garage" prior posts.
And thanks to all others for the suggestions. I showed this forum to a friend that owns an old Mercedes , he couldn't believe the camaraderie and quick responses to technical issues of other members (other than the battle going on with the dude and his "first look at a 914" post (IMG:style_emoticons/default/lol-2.gif) )
dlee6204
post Dec 15 2012, 09:11 PM
Howdy
QUOTE(markyb @ Dec 15 2012, 07:37 PM) *
Have you seen this thread? It also has a VPC wiring diagram... (IMG:style_emoticons/default/smile.gif)
http://www.914world.com/bbs2/index.php?showtopic=192917
markyb
post Dec 16 2012, 07:14 PM
I'm not sure how I missed that post, but you saved me a lot of work by pointing it out! I have to read it later when I have some free time. From some older posts I remember that there is an adapter bracket sold by Bus Depot that will allow me to put the Sanden unit on my York mount.
Thanks again
- Lo-Fi Version Time is now: 17th November 2026 - 04:27 PM
