Will's progress Thread, It Starts |
qa1142 |
Nov 11 2004, 06:44 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
yep
it is really sitting on only 3 stands, the one you marked is not touching. I put my jacks under the longs last night when I was popping ball joints, etc. plan is, clean surface rust Touch up paint (this is all inside and underneath) Put front suspension back on Put front end back on ramps then pull motor and work on bake end stuff. |
RON S. |
Nov 11 2004, 07:05 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Very good looking undersides.
That'll be a muchhhhh easier fix than a lot of us around here have been used to. Ron |
qa1142 |
Nov 11 2004, 06:58 PM
Took my body saw to the left jack post support. I plan to replace bottom half only.
If I clean this up, Por15 and weld on the new piece I think it will last another 30 years (no winters and little to not rain days) What do you all think? Attached image(s) |
qa1142 |
Nov 11 2004, 07:00 PM
another angle
qa1142 |
Nov 11 2004, 07:03 PM
Check out how clean the torsion bars came out. is this normal?
qa1142 |
Nov 11 2004, 07:06 PM
dakotaewing |
Nov 11 2004, 07:08 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Will,
Before anybody makes any comments on your jackposts, the metal needs to be ground clean before a true and accurate conclusion can be made.... Just my .0002... Thom (IMG:style_emoticons/default/wink.gif) |
qa1142 |
Nov 11 2004, 07:10 PM
Left (drivers) side
Front front looked fine Attached image(s) |
william harris |
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Thanks for the pictures. This is exactly where I was about 1 year ago. Pulled a running 914 into the garage and began the same process. Problem was I couldn't stop. Now I have just (almost exactly one year later) brought the media blasted and primed tub home to continue the effort. I really want to finish the body and get the suspension back on the car this winter. This means installing the brake lines, fuel lines and wiring harness first. If you are going to keep the car on jack stands for long, I recommend 2x8s as they provide a great deal more support and height. I ran them completely across the the car at three points. Keep em coming. I feel like we are comrades in this effort. (IMG:style_emoticons/default/beerchug.gif) My torsion bars looked just like yours, except almost no grease. (IMG:style_emoticons/default/biggrin.gif)
qa1142 |
Nov 11 2004, 07:18 PM
Plan is to get the jack post rust in check.
Clean up treat and prep surface rust. cover in blue then all mechanical - back to near new (IMG:style_emoticons/default/mueba.gif) That will give me time to get back to full chassie restoration in a year or two. Lynne is working tomorrow night, I plan to spend whatever it takes to get the one jack post ready. I'll get you those bare metal photos tomorrow. Anyone want to come and help? (IMG:style_emoticons/default/beerchug.gif) |
GaroldShaffer |
Nov 11 2004, 08:52 PM
QUOTE Anyone want to come and help? I would but my weekend in booked. (IMG:style_emoticons/default/mad.gif) Nothing like learing how to do something on some elses car (IMG:style_emoticons/default/cool_shades.gif) Seriously, the week on Thanksgiving is open for me. If you need help let me know. -Garold |
Root_Werks |
Nov 12 2004, 10:10 AM
Village Idiot Group: Members Posts: 8,320 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Looks great Will! I see mostly surface rust, easy fixes. Like most have already said, get rid of the rust and poke with a screw driver to make sure things are solid. If you are solid, most of it can probably just be cleaned up and painted. POR-15 rocks. I bought a quart and didn't use all of it. If you put the lid back on, use a plastic bag (Keeps lid from sticking to can) and stick it in the fridge. It will last longer. I didn't do that to mine. Now I can't get the can open! (IMG:style_emoticons/default/ohmy.gif)
qa1142 |
Nov 12 2004, 07:10 PM
Well
Dug into left jack point today. metal is layered there??? looks like long goes behind the rear sub-frame??? Top layer is rusted through in spots. Clean solid metal all the way around where the jack post support was spot welded to the subframe. Surface rust cleaned up well under the long/subframe. If I weld this 1/2 post support in, will that be good enough? What is top layer here, the rear sub-frame? what bits would I need to patch in clean metal here?? Take a look at these pictures... Attached image(s) |
qa1142 |
Nov 12 2004, 07:13 PM
another view
qa1142 |
Nov 12 2004, 07:18 PM
If I por15 it and weld this piece in.... (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
qa1142 |
Nov 14 2004, 06:07 PM
Lazy today, Bears WON
I drained and pulled gas tank. pulling petals is next. Everything looks good (no real rust) couple of little spots where tank rubbed and I have surface rust. Today's pictures Attached image(s) |
Aaron Cox |
while the tank s out..put a swaybar in. you wont regret it!
qa1142 |
Nov 14 2004, 06:14 PM
picture 2
I'll install fuel lines and sway bar before tank goes back in. Attached image(s) |
aircooledboy |
Nov 14 2004, 06:15 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
QUOTE(qa1142 @ Nov 14 2004, 06:07 PM) Lazy today, Bears WON (IMG:style_emoticons/default/w00t.gif) Offense? We don need no stinking offense. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) GO BEARS!!!!!!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/monkeydance.gif) |
type47fan |
Nov 14 2004, 06:18 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Lo-Fi Version | Time is now: 16th May 2024 - 12:19 PM |
