| Java2570 |
Dec 18 2012, 07:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I've purchased a couple of different sets of main bearings for my engine rebuild, 1 set of Mahle and 1 set of Silverlines.....I received both with appear to be light scuffs and surface scratches on the bearing surfaces, apparently from the way they are packaged from the factories. The vendor I bought the Silverlines from says this is common and he has used them with no issues. What's the word on this, should I be concerned about this or not? Common sense tells me the bearing surfaces should be mark free and smooth.....
Java2570 Maiin bearings Dec 18 2012, 07:17 AM
Cupomeat I suppose it all depends on how bad the surfaces a... Dec 18 2012, 07:21 AM
Java2570
I suppose it all depends on how bad the surfaces ... Dec 18 2012, 07:27 AM
Mark Henry Didn't feel them much or not at all? Which is ... Dec 18 2012, 08:19 AM
Java2570
Didn't feel them much or not at all? Which is... Dec 18 2012, 06:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 05:07 AM |
