76 914 2.0l four |
76 914 2.0l four |
jdlmodelt |
Dec 18 2012, 06:48 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
what VW clutch kits are compatible with the Porsche 914 2.0l four cylinder fuel injected engine? Is this the VW bus engine? I guess since the transmission is different, the clutch assembly probably is too?
914Sixer |
Dec 18 2012, 07:01 PM
914 Guru Group: Members Posts: 8,883 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just get the kit listed for the 914. Too many variables using some bus clutches. Some discs have 4 springs, some have 6 spring. Throw out bearing is 911/914 only. Pressure plates have different finger pressure or used too.
jdlmodelt |
Dec 18 2012, 10:43 PM
Mark Henry |
Dec 19 2012, 12:00 AM
901 tranny uses a slightly different flywheel/PP/clutch disc arrangement.
If you want to put a bus engine in a 914 use the 914 flywheel/PP/clutch disc. You can often put a WTB in the classifieds and get a good used set, at a reasonable cost, if you're on a budget. |
Ian Stott |
Dec 19 2012, 12:40 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
My understanding is the flywheel is the same part # as the bus, check out Jake Raby, I got my assembly from him, the 6 spring one and he matches the surfaces before he sends it out. Mine is very smooth, but then I am a professional driver!
Ian Stott Moncton Canada 73 2.0 |
Lo-Fi Version | Time is now: 19th May 2024 - 06:40 AM |
