jdlmodelt
Dec 18 2012, 06:48 PM
what VW clutch kits are compatible with the Porsche 914 2.0l four cylinder fuel injected engine? Is this the VW bus engine? I guess since the transmission is different, the clutch assembly probably is too?
914Sixer
Dec 18 2012, 07:01 PM
Just get the kit listed for the 914. Too many variables using some bus clutches. Some discs have 4 springs, some have 6 spring. Throw out bearing is 911/914 only. Pressure plates have different finger pressure or used too.
jdlmodelt
Dec 18 2012, 10:43 PM
QUOTE(914Sixer @ Dec 18 2012, 06:01 PM)
thanks,
will do.
Mark Henry
Dec 19 2012, 12:00 AM
901 tranny uses a slightly different flywheel/PP/clutch disc arrangement.
If you want to put a bus engine in a 914 use the 914 flywheel/PP/clutch disc.
You can often put a WTB in the classifieds and get a good used set, at a reasonable cost, if you're on a budget.
Ian Stott
Dec 19 2012, 12:40 PM
My understanding is the flywheel is the same part # as the bus, check out Jake Raby, I got my assembly from him, the 6 spring one and he matches the surfaces before he sends it out. Mine is very smooth, but then I am a professional driver!
Ian Stott
Moncton
Canada
73 2.0
