Let's talk fuel pumps, for carbs |
nebreitling |
Nov 7 2004, 09:27 PM
i'm looking at a Holley Red or a Carter 4070 fuel pump to feed 44 idf's on a high-ish compression 2 liter with an angressive cam. anyone had any experience with either pump? got something else that you like?
machina |
Nov 8 2004, 06:26 AM
The holley's are pure junk. The pump casting is very poorly made. Mine cracked.
Get the Mallory 4070 LP. It is a low pressure pump but you'll need a return regulator. The pump is machined from billet and is just loud enough to hear power up. Also only draws 2.5 amps. I think an easier route is one of the facets. I don't know anything about the carter. Attached image(s) |
type11969 |
Nov 8 2004, 06:42 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I'm using a cheap facet pump (came with the car), but in order to get the proper pressure at the carbs, you really need a pressure regulator too. Instead you could just buy the rotary fuel pump at ac.net that is internally regulated to the 3-3.5 psi that your carbs will need. I used to have one, they are pretty quiet, at least much more so than the facet.
http://www.aircooled.net/new-bin/viewprodu...FSP0001&cartid= -Chris |
SLITS |
Nov 8 2004, 10:52 AM
Used them all - FACET is cheap and works....................................
iamchappy |
Nov 8 2004, 10:56 AM
I personally like the 914 6 pump, I have one thats been sitting around for awhile if your interested.
rhodyguy |
Nov 8 2004, 11:02 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the rotary from cbperformance for $53.95 is the deal. hardware included.
kevin |
Joe Bob |
Nov 8 2004, 11:09 AM
Facets are loud but are stupid proof....good in SLITS' case.... (IMG:style_emoticons/default/biggrin.gif)
Rotary ones are nice and quiet,,,,but I have yet to have one for a long time to judge endurance....I prefer to hear my pump fire up...most of my engines will drown out the pump once running. The radios will drown out the engine if I so choose.... |
Root_Werks |
Nov 8 2004, 11:13 AM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I am running a Facet (the big one) the $79 one? and a pressure reg set at 3.5lbs. Pretty quiet, I can hardly hear it before starting the engine. Also mounts nicely in the factory spot.
aircooledboy |
Nov 8 2004, 11:18 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
I am running a Carter on the 8, and even mounted on rubber isolators, it sounds like a jackhamer about 70% of the time. (IMG:style_emoticons/default/wink.gif)
bernbomb914 |
Nov 8 2004, 11:34 AM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I agree about the jack hammer sound
for the carter pump very loud (IMG:style_emoticons/default/headbang.gif) Bernie |
SteveSr |
Nov 8 2004, 11:41 AM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
Does Mallory make that billet pump for fuel injection?
SteveSr |
scooter311 |
Nov 8 2004, 11:46 AM
Member Group: Members Posts: 231 Joined: 22-October 04 From: Upstate NY Member No.: 2,986 |
Heya
My Holley red and a regulator work fine for me - 2056 with 40s, big cam, and press set at 5. Seems to work best there? Mine looks different from the pic though, my top casting is round. Pretty loud though, fun at the gas station to see people gawk. (IMG:style_emoticons/default/rolleyes.gif) |
ClayPerrine |
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
QUOTE(SteveSr @ Nov 8 2004, 09:41 AM) Does Mallory make that billet pump for fuel injection? SteveSr Yep. Got one sitting in a box at home. Never been used. Cost me 2 bills. Left over from my hot rodding days. Never installed the EFI on the small block that I bought it for. |
machina |
Nov 8 2004, 11:50 AM
QUOTE(SteveSr @ Nov 8 2004, 01:41 PM) Does Mallory make that billet pump for fuel injection? SteveSr yes, they make several pumps. Check summit or the mr gasket website. |
machina |
Nov 8 2004, 11:51 AM
QUOTE(scooter311 @ Nov 8 2004, 01:46 PM) My Holley red and a regulator work fine for me - 2056 with 40s, big cam, and press set at 5. Seems to work best there? Mine looks different from the pic though, my top casting is round. that's the problem with them 5psi is way too much for webers. |
dinomium |
Nov 8 2004, 11:53 AM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
I had the CB performace pump and it worked GREAT. I hated my faucet pump... Now Shane has the rotary pump on his car.
J P Stein |
Nov 8 2004, 11:59 AM
I've been running Facet with no regulator for 4-5 years. No problems except with the noise. ...but when the motor's lit, it fades into background noise....along with everything else (IMG:style_emoticons/default/biggrin.gif)
IIRC, they have 2 models.....3.5 & 4.5 psi. I use the 4.5 duber. |
theol00 |
Nov 8 2004, 12:25 PM
Member Group: Benefactors Posts: 242 Joined: 22-January 04 From: Campbell, CA Member No.: 1,586 |
I had to replace the holley after 3 month - repaced it with a Facet - it is much quiter/samller/lighter and works well
Lo-Fi Version | Time is now: 27th April 2024 - 10:00 PM |
