Tranny Crack Opinions Wanted, (Now that just sounds silly) |
wndsnd |
Dec 20 2012, 03:21 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Woody |
Dec 20 2012, 08:42 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
What part of the tranny?
wndsnd |
Dec 20 2012, 08:49 PM
Rear under muffler bracket mounts. I can take another picture tomorrow.
Dr Evil |
Dec 20 2012, 09:33 PM
Is it on the tail cone? Tail or side shift? If it is the tail cone you have two options:
1) Grind it out, clean it real good and Quiksteel it. 2) Replace the tail cone. |
bandjoey |
Dec 20 2012, 09:34 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
If it's not in a fluid area, stop drill the holes and fill with JB weld. If in fluid area, JB weld and pack it in.
Mark Henry |
Dec 20 2012, 09:46 PM
Is it a real crack or just a superficial casting flaw?
Most of the mag damage I've seen is corrosion, bends real bad, snaps right off or has a big fuching hole in it. Degrease it, sand it with coarse grit paper, degrease it again sand it some more and JB weld it. JB weld tends to run, so stand it up so the repair is level as you can get it, make a putty dam if needed. |
wndsnd |
Dec 20 2012, 10:20 PM
It is the tail cone od a side shift. The vertical line is casting only looks like a crack. The cleaned area is acrack. Doesn't leak. So grind out a bit and jbweld?
wndsnd |
Dec 20 2012, 10:21 PM
ChrisFoley |
Dec 21 2012, 12:04 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have magnesium filler wire if you're interested in getting a proper weld on that.
Dr Evil |
Dec 21 2012, 06:42 AM
I live in Washington, pa. Not close, but shipping is easy. Welding that crack would likely be cost prohibitive.
ChrisFoley |
Dec 21 2012, 07:28 AM
Welding that crack would likely be cost prohibitive. Depends on what you consider cost prohibitive. Whats the price of a good used replacement? A good welder, experienced at welding Mg, would make short work of that crack. Not that I know anything about welding... (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:49 PM |
