throttle cable routing, throttle cable routing |
jdlmodelt |
Dec 23 2012, 09:58 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
I can't find any illustrations. how does the throttle cable route from the firewall to the throttle linkage on the 76 2.0l fuel injected engine? I have a 72 with the 76 2.0l engine going in it. I recently purchased this project not completely assembled and have been looking thru all the books to determine what goes where. Any posting suggestions to help me correctly reassemble this car would be much appreciated.
silver74insocal |
Dec 23 2012, 10:02 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
i had a similar issue, check out the originality forum. there is a thread there showing engine bays. good luck and (IMG:style_emoticons/default/welcome.png)
SLITS |
Dec 23 2012, 10:05 PM
If you are talking about from the engine firewall to the accelerator pedal, it is a cable that passes through the center tunnel in a tube.
If you are talking about how it connects to the TB, it is routed from the firewall thu a hole in the passenger side engine tin, up to the TB where it secured in a bracket (sheathing) and the cable itself to a barrel nut in the TB linkage. (IMG:style_emoticons/default/drunk.gif) Shit that was tough to type .... backspace................. |
jdlmodelt |
Dec 23 2012, 10:43 PM
that's it! thanks! Now...what else do I need to connect? Emergency brake cables...then...what holds the headlights in place?
jdlmodelt |
Dec 23 2012, 10:45 PM
what does the front hood release cable look like? I have a few hundred parts and don't know what they look like...exactly
bugsy0 |
Dec 23 2012, 10:55 PM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
runs in a plastic sheath over the top of the left front fender, along the inside of the front panel to the mechanism. see spot welded hold-down tabs along that route.
jdlmodelt |
Dec 23 2012, 11:15 PM
runs in a plastic sheath over the top of the left front fender, along the inside of the front panel to the mechanism. see spot welded hold-down tabs along that route. I need to take a pic of the cable that I think it is and see what you think. I don't know what the ebrake cables are supposed to look like as well. |
SLITS |
Dec 24 2012, 07:15 AM
runs in a plastic sheath over the top of the left front fender, along the inside of the front panel to the mechanism. see spot welded hold-down tabs along that route. I need to take a pic of the cable that I think it is and see what you think. I don't know what the ebrake cables are supposed to look like as well. One long and one short .... heavy cables. No pic till later today, |
Lo-Fi Version | Time is now: 27th May 2024 - 08:56 AM |
