Vintage Brake - 914-6/GT Alloy Rear Calipers, Now Shipping! |
Eric_Shea |
Dec 25 2012, 08:19 PM
Finally!!! The answer for those wanting the legendary 914-6/GT rear calipers on their car. New, ultra lightweight alloy rear calipers from "Vintage Brakes" are shipping now.
Experience the legendary stopping power the factory race team had when they won LeMans back in 1970. These 914-6/GT calipers give you a 38mm piston which is 15% larger than a stock 914 rear caliper piston. They also use an FMSI standard D31 pad which is 13% larger than stock 914... all in a package that is 5lbs. lighter per side! That's 10lbs. of unsprung weight taken off the back of your 914 race car (or 911 for that matter... drop the handbrake assembly and loose even more weight). So... what does this mean for you? Well, the larger piston and pad size mirror that of it's Brother, the 911. Nearly every 911 had a 38mm piston and D31 pad in the rear from the legendary 911RS to the last 911SC in 1983. In fact, this is the same arrangement the factory put in a 914-6. Have you checked the prices on used 914-6 and 914-6/GT calipers (if you can find these hens teeth)? This means you can now bolt on just about any 911 front caliper you'd like and maintain a factory brake bias. Want to run a 914-6 stock setup? Run these (stock 6 versions are without spacers and $100 less) and a pair of 911 M-Calipers up front. Move up to legendary GT status? Add a pair of S-Calipers (cast off the same 908 casting the LeMans cars ran) and run these in the back. So now you can finally bolt on some brakes to your 914 and have it "factory perfect." Handbrake? You bet, you can have big brakes and a stock handbrake assembly. Use stock handbrake cables and have a system designed specifically for your 914... a 914 handbrake system! Our DuroAno finish on the calipers and the specifically designed pistons make these harder than steel! Our upgraded M8 (over stock M7) fasteners help keep the flex down to .002" (human hair) over their steel counterparts. While you probably won't need vented rotors in the rear of your 914, these GT versions have the spacers added so they fit over wider, cooler running vented rotors*. Finally, the perfect solution for all of these 914's that have a nice bump in horsepower... a nice bump in stopping power. *Used with stock 911 rear rotors, these will need about 4.5mm worth of spacers (washers) under the caliper mounting ears or a spacer "under" the rotor. 914-6/GT rear rotors are still available from the factory for those who want to get the real deal from Germany (call for a quote). (IMG:http://www.914world.com/bbs2/uploads_offsite/4.bp.blogspot.com-1110-1356488929.1.jpg) PMB Performance 162 W. 9240 S. Sandy, UT 84070 855-STOP-101 855-786-7101 sales@pmbperformance.com www.pmbperformance.com Love us on Facebook: https://www.facebook.com/PMBPerfomance http://www.pmbperformance.com/catalog/item...676/9663436.htm] (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.com-1110-1356488397.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.com-1110-1356488398.2.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.com-1110-1356488398.3.JPG) |
914werke |
Feb 5 2018, 11:58 PM
"I got blisters on me fingers" Group: Members Posts: 10,077 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
But the question remains.
If they were so Fab, at a great price, with what appears to be a decent demand... Why are they no longer available? Litigation? Did material or component price suddenly change? did they have an unusually high return/failure incidence? Or ...something else entirely Inquiring minds what to know (IMG:style_emoticons/default/smile.gif) |
raynekat |
Feb 6 2018, 07:13 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
But the question remains. If they were so Fab, at a great price, with what appears to be a decent demand... Why are they no longer available? Litigation? Did material or component price suddenly change? did they have an unusually high return/failure incidence? Or ...something else entirely Inquiring minds what to know Only Eric can answer that properly I believe. I think they were just a PITA to manufacture. |
ConeDodger |
Feb 10 2018, 12:41 PM
Apex killer! Group: Members Posts: 23,593 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
But the question remains. If they were so Fab, at a great price, with what appears to be a decent demand... Why are they no longer available? Litigation? Did material or component price suddenly change? did they have an unusually high return/failure incidence? Or ...something else entirely Inquiring minds what to know Only Eric can answer that properly I believe. I think they were just a PITA to manufacture. That’s what I heard too. Remember, Eric has built PMB to the point that he has a 3 year backlog of work. I don’t think he wants the hassle of group buys and such, plus, I don’t think he profited too much even at retail. Good score on the genuine article Mark! |
mepstein |
Feb 10 2018, 01:01 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
But the question remains. If they were so Fab, at a great price, with what appears to be a decent demand... Why are they no longer available? Litigation? Did material or component price suddenly change? did they have an unusually high return/failure incidence? Or ...something else entirely Inquiring minds what to know Only Eric can answer that properly I believe. I think they were just a PITA to manufacture. That’s what I heard too. Remember, Eric has built PMB to the point that he has a 3 year backlog of work. I don’t think he wants the hassle of group buys and such, plus, I don’t think he profited too much even at retail. Good score on the genuine article Mark! Yes, a very nice member from Texas sold them to me. They will go on a future build. I had another set that I bought but sold to Dion for what I paid just because I felt that they were perfect for his car. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:17 AM |
