WTB: Front End Rubber, Replacing Ball Joints, Tie Rods, etc |
7TPorsh |
Dec 26 2012, 12:07 PM
I am slowly accumulating pieces to refurbish my front end. Rather than piece it all together shopping on ebay and here I though maybe I can get the whole setup here easily and in true CSOB style.
Here is what I am looking for...preferably new and all from the same place but ok to split I guess. Again looking for value. Debating on getting the turbo tie rod kit. Car is a 1970 /4 and a streeter; no racing. If I don't really need the kit than great. Good parts brands vs. great parts are probably ok too. Front Bushings - Poly acquired from GPR Lower Ball Joints- Turbo Rod Kit or Tie Rod Ends Anything Else???? Also think I need a cross member section; the piece bolted to the steering rack. Looks really corroded...local for this one since heavy |
running914 |
Dec 26 2012, 01:31 PM
Member Group: Retired Members Posts: 60 Joined: 9-October 12 From: pennsylvania Member No.: 15,021 Region Association: None |
[attachmentid=355
686] I am slowly accumulating pieces to refurbish my front end. Rather than piece it all together shopping on ebay and here I though maybe I can get the whole setup here easily and in true CSOB style. Here is what I am looking for...preferably new and all from the same place but ok to split I guess. Again looking for value. Debating on getting the turbo tie rod kit. Car is a 1970 /4 and a streeter; no racing. If I don't really need the kit than great. Good parts brands vs. great parts are probably ok too. Front Bushings - Poly acquired from GPR Lower Ball Joints- Turbo Rod Kit or Tie Rod Ends Anything Else???? Also think I need a cross member section; the piece bolted to the steering rack. Looks really corroded...local for this one since heavy hello, here are some control arms with ball joint and bushings in very good condition, If this would help you email me at running914@hotmail.com Attached thumbnail(s) |
euro911 |
Dec 26 2012, 01:37 PM
Gary,
AZ Autohaus is where I bought all my front end parts (all Lemforder stuff): These are for a 1970 Porsche 914/4 Ball Joints Click here Tie Rod Ends Click here or Complete Tie Rod Assemblies Click here EDIT: If you want to upgrade to the Turbo Tie Rods: Click here Spacer/Washers Click here Boots Click here You can do the upgrade for about the same price (IMG:style_emoticons/default/idea.gif) |
bdstone914 |
Dec 26 2012, 01:52 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am slowly accumulating pieces to refurbish my front end. Rather than piece it all together shopping on ebay and here I though maybe I can get the whole setup here easily and in true CSOB style. Here is what I am looking for...preferably new and all from the same place but ok to split I guess. Again looking for value. Debating on getting the turbo tie rod kit. Car is a 1970 /4 and a streeter; no racing. If I don't really need the kit than great. Good parts brands vs. great parts are probably ok too. Front Bushings - Poly acquired from GPR Lower Ball Joints- Turbo Rod Kit or Tie Rod Ends Anything Else???? Also think I need a cross member section; the piece bolted to the steering rack. Looks really corroded...local for this one since heavy I have many cross members. Free if you pick it up in riverside. The a arms you were offered will not fit your car as you need the pinch bolt type not the taper pin type. Bruce |
70-914nut |
Dec 26 2012, 03:19 PM
Member Group: Members Posts: 119 Joined: 15-March 11 From: Elizabeth city nc Member No.: 12,826 Region Association: None |
I am slowly accumulating pieces to refurbish my front end. Rather than piece it all together shopping on ebay and here I though maybe I can get the whole setup here easily and in true CSOB style. Here is what I am looking for...preferably new and all from the same place but ok to split I guess. Again looking for value. Debating on getting the turbo tie rod kit. Car is a 1970 /4 and a streeter; no racing. If I don't really need the kit than great. Good parts brands vs. great parts are probably ok too. Front Bushings - Poly acquired from GPR Lower Ball Joints- Turbo Rod Kit or Tie Rod Ends Anything Else???? Also think I need a cross member section; the piece bolted to the steering rack. Looks really corroded...local for this one since heavy I have many cross members. Free if you pick it up in riverside. The a arms you were offered will not fit your car as you need the pinch bolt type not the taper pin type. Bruce http://www.914world.com/bbs2/index.php?showtopic=196611 check this out and let me know what you think. |
7TPorsh |
Dec 26 2012, 04:30 PM
am i going to see a huge difference if I do the turbo tie kit vs. just new ends?
mittelmotor |
Dec 26 2012, 05:26 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Another thing that might need some attention while you're in there is the steering coupler between the rack and steering shaft...they can degrade and generate some slop/looseness in the system. I should've done mine when I had it apart!
Evil914 |
Dec 26 2012, 10:46 PM
Newbie Group: Members Posts: 46 Joined: 25-October 10 From: mineral wells,texas Member No.: 12,309 Region Association: Southwest Region |
Gary, AZ Autohaus is where I bought all my front end parts (all Lemforder stuff): These are for a 1970 Porsche 914/4 Ball Joints Click here Tie Rod Ends Click here or Complete Tie Rod Assemblies Click here EDIT: If you want to upgrade to the Turbo Tie Rods: Click here Spacer/Washers Click here Boots Click here You can do the upgrade for about the same price (IMG:style_emoticons/default/idea.gif) Hey,thanks for that info.I know where I'm buying my front-end parts,great prices!! (IMG:style_emoticons/default/piratenanner.gif) |
euro911 |
Dec 27 2012, 02:12 AM
am i going to see a huge difference if I do the turbo tie kit vs. just new ends? I'll let you know after I get everything installed (IMG:style_emoticons/default/laugh.gif) Word is, yes, but if yours are the originals and worn out, just installing new ball joints and rod ends it will definitely provide improvement over 30+ year old ones. I decided to go with the turbo rods as I occasionally get a little aggressive behind the wheel (IMG:style_emoticons/default/driving.gif) |
7TPorsh |
Dec 27 2012, 01:37 PM
Ok, ordered the ball joints, tie rod ends, and boots
Great tips. Whats the steerring coupler...uni joint? Have to start shopping for the rear end...rear bushings...AA has some good prices no? (don't shoot me) http://www.autoatlanta.com/Porsche-Polygra...R993015335.html |
Lo-Fi Version | Time is now: 13th May 2024 - 06:09 AM |
