My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
Chris H. |
Jan 27 2013, 11:06 AM
Thanks for the insight jcl... the alternator setup is going to be key...
Hey carrying over my hijack of strawman's thread (sorry man) ... been looking at stock Subie gauge clusters... does anyone know if the tach needs calibration like a 914's? How about compatibility? The reason I ask is that the bone yards and e-bay show compatibility with either 4 cylinder or 6 cylinder cars. Example: Legacy Cluster Note how it says either 2.5L or 3.0L...Could be a mistake... my ideal setup would be something like this: 2004 WRX Or this: 05 STI Just not sure if it would be possible without more $$$$ than the Speedhut setup. Any insight would be appreciated. |
strawman |
Jan 27 2013, 01:58 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
... been looking at stock Subie gauge clusters... does anyone know if the tach needs calibration like a 914's? How about compatibility? IMHO, the easiest solution is to match the cluster's native number of cylinders with the sixer in your car. But I'm sure there's a way to use resistors, amps or clamps (or some other techie solution!) in-line between the ECU and Suby cluster if you choose to go with a WRX cluster. All of the Legacy gauges I looked at were too wide for my liking, but if you're gonna hack up the 914 dash anyway (like I did!), I guess it really doesn't matter. 904svo (Larry) is an electrical whiz and REALLY helped me build a converter to use the 914 tach. (IMG:style_emoticons/default/beerchug.gif) I've still got the converter (see below) and could pass-it-forward if you can use it, though you'd need to convert it to work with the six-cylinder signal. PM me if you're interested (and be sure to thank Larry!). You'd still be challenged with the speedo, since the Suby uses a VSS signal versus the cable-driven 914 speedo. I looked at using a VSS-based 911 speedo, but my cheap-ass couldn't stomach paying ~$100 for a questionable used one and prolly need to send it in for a $350 rebuild... most of the cheap ones are 85mph, too. (IMG:style_emoticons/default/barf.gif) Keep up the great work! Geoff |
904svo |
Jan 27 2013, 04:33 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
... been looking at stock Subie gauge clusters... does anyone know if the tach needs calibration like a 914's? How about compatibility? IMHO, the easiest solution is to match the cluster's native number of cylinders with the sixer in your car. But I'm sure there's a way to use resistors, amps or clamps (or some other techie solution!) in-line between the ECU and Suby cluster if you choose to go with a WRX cluster. All of the Legacy gauges I looked at were too wide for my liking, but if you're gonna hack up the 914 dash anyway (like I did!), I guess it really doesn't matter. 904svo (Larry) is an electrical whiz and REALLY helped me build a converter to use the 914 tach. (IMG:style_emoticons/default/beerchug.gif) I've still got the converter (see below) and could pass-it-forward if you can use it, though you'd need to convert it to work with the six-cylinder signal. PM me if you're interested (and be sure to thank Larry!). You'd still be challenged with the speedo, since the Suby uses a VSS signal versus the cable-driven 914 speedo. I looked at using a VSS-based 911 speedo, but my cheap-ass couldn't stomach paying ~$100 for a questionable used one and prolly need to send it in for a $350 rebuild... most of the cheap ones are 85mph, too. (IMG:style_emoticons/default/barf.gif) Keep up the great work! Geoff That tach adapter will drive a 911 tach off a 6 cylinder engine also. The trouble with using the Subaru Speedo is that it will only read the correct speed if you use the same tire size as the Subaru, also there is no way to fix it as it control by the speedo chip in the gauge panel. |
strawman |
Jan 27 2013, 06:49 PM
The trouble with using the Subaru Speedo is that it will only read the correct speed if you use the same tire size as the Subaru, also there is no way to fix it as it control by the speedo chip in the gauge panel. Guys on NASOIC have had success with the SpeedoHealer. Cost is about $120, but it can be used with any VSS-equipped motorcycle or automobile. I was planning on using one of these... |
Lo-Fi Version | Time is now: 16th May 2024 - 01:53 PM |
