My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
Chris H. |
Aug 1 2013, 06:23 PM
Got the old engine out! I'm feeling a little bad about the engine swap but I think I'll get over it. The 1.8l is so original and unmolested... (but dusty)
Amazingly similar.... What do these numbers mean? a 1.0L!? All the heater tube clamps are the original VW embossed ones... Back pad is awesome - just some paint on it but otherwise very good. When I got back from my last drive of 2012 it was running a little rough....this MIGHT by why....#2 plug wire ripped out of its sheath. Ran pretty good on three cylinders for a few miles! Got the rear hubs pressed Engine hole - anyone know how to remove the glue that holds the back pad on? The paint under it is pristine!!! |
Lo-Fi Version | Time is now: 14th May 2024 - 09:57 PM |
