My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
DBCooper |
Jan 28 2013, 09:13 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Yup, that's it. Found a photo:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1359386016.1.jpg) Fully programmable so you can change tire height and correct the speedo. The tach is also VDO, with a programmable shift light (that LED just above the VDO logo). The shift light looks small but it's pretty bright, without looking like a drag racer. And it goes up to 9K, appropriate for a Subaru engine that spins higher than a T4. It was about $100 from e-bay new in the box. The fonts and style are the same so it leaves the dash looking "in the style of" the original, but with modern instruments. The tach and speedo needles have absolutely no bounce, are perfectly steady. They work well and are simple to install. Important to note that I use an aftermarket EMS, so no need to retain any Subaru compatibility for ECU function. They're great, the only real problem is lighting at night, they're all a little different. I still haven't changed the bulbs in all so they match. That photo makes the needle colors look different, which is odd, but in real life I can't tell the difference. . |
Lo-Fi Version | Time is now: 29th April 2024 - 04:25 AM |
