My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
Chris H. |
Jun 5 2013, 03:57 PM
Hey Jim,
Believe it or not the engine is being held in place almost entirely by the mounts coming up from the engine bar. They are VERY strong: Although the front wood piece does provide a small amount of support it's barely touching the pan. It does stop forward movement at some point though and I think that is critical until the trans is hooked up. We're talking 80/20 weight distribution here.... The initial idea behind the wood frame was to keep the oil pan above ground when I lowered the engine down from the stand. Then I realized it could be extended back to the trans mounts and slightly change the weight distribution so that the engine doesn't flop forward onto the floor. If it wasn't for my novice mistake of forgetting the flywheel bolts the trans would already be in and the lump would be pretty evenly weighted. I want to get it running before I put it in so that will be next. Hopefully Ian will make some cable kits so I don't have to fab my own. Are you done with your conversion Jim? |
Lo-Fi Version | Time is now: 29th April 2024 - 08:52 AM |
