My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
nsyr |
Jun 5 2013, 05:33 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
I would be careful with those mounts. They are fluid filled and known to come apart. Both of mine have come apart. The replacement cost I believe is around 200 each! I will be replacing mine with sti mounts which have to be retrofitted.
Chris H. |
Jun 5 2013, 05:56 PM
I would be careful with those mounts. They are fluid filled and known to come apart. Both of mine have come apart. The replacement cost I believe is around 200 each! I will be replacing mine with sti mounts which have to be retrofitted. Thanks Andrew, very good point. Yes they are vulnerable and pricey ($271 each at last check). I literally have not moved that thing an inch to keep stress at a minimum. Didn't plan to leave it like that for this long but they seem fine. Seems like this is not the first set for the engine... The bolts arrive tomorrow. |
Lo-Fi Version | Time is now: 29th April 2024 - 02:15 AM |
