Now that the racing/ax season is over, How many cars are now on jackstands? |
URY914 |
Nov 9 2004, 08:58 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,544 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I'm done for a few months so the car will assume its position on jack stands.
I plan on: 1. Pulling the engine 2. Adding bars to tie the shock towers to the main hoop. 3. Cutting the firewall out. 4. Cutting the passenger side floor out. 5. Replacing the targa bar with f/g. 6. Replacing the remaining steel in the rear quaterpanels with f/g. 7. Cut off the jack recievers 8. Cut out the sheet metal between the shock towers. 9. Clean up the fit of the body panels. What's everyone use got planned? If you post what you're going to do, we'll come back in 2-3 months and check everyones progress. Paul |
machina |
Nov 9 2004, 09:08 AM
I'm up on stands, but just until friday, and hey, my season is just starting. I got Moroso this weekend, a PBOC race at homestead in december and then january nationals if they let us regional guys run. (IMG:style_emoticons/default/driving.gif)
ChrisFoley |
Nov 9 2004, 09:11 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I already pulled the engine, but the car is back on the ground for a while.
In additon to more power my winter upgrade plans include some oil system work and brake cooling work. |
DNHunt |
Going up soon.
New engine Upgrade EFI to do ignition Replace throttle cable New seals in tranny and change Sweptco Check and retorque suspension, lube zerk fittings. Get it off the jackstands and tune it. Dave |
Part Pricer |
Nov 9 2004, 09:14 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Jackstands?? Not yet. We've got one more AX this coming weekend. It should be interesting. Forecast calls for temps in the upper 30's - low 40's and I've got no heat in the 914.
Where's that shivering smilely? |
d914 |
Nov 9 2004, 09:15 AM
new or redesigned fuel cell
pull engine and add some more bracing clean her up new fuel pump otherwise good I hope!! |
J P Stein |
Nov 9 2004, 09:41 AM
It isn't up on blocks yet, but the winter is young.
The approximate priority: Add slicks, which means more flare in the rear. Stiffer rear springs Get a light weight battery & move it to the front trunk. 5 gallon fuel cell. Wish list: FG lids LSD Paint (IMG:style_emoticons/default/wacko.gif) |
mike_the_man |
Nov 9 2004, 09:51 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Yup, already on jack stands. I'm in the process of re-doing the front suspension right now. New ball joints, tie rods, bushings, and shocks.
After that is done, I'm hoping to: strip out the interior recover seats and door panels strip tar off the floor boards weld in an inner long stiffening kit I'm also in the middle of gutting and remodeling my basement, so who knows how much car stuff will get done. |
slivel |
Nov 9 2004, 09:59 AM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
On jackstands. List of mods includes installing polybronze bushings front and rear from Elephant Racing, stacked springs (linear rate on top of progressive rate) on all four corners, realignment, 23mm master cylinder, new windshield, adjust valves, change oil and CLEAN the car.
Steve |
drew365 |
Nov 9 2004, 10:27 AM
No jackstands yet, we have one more event at Buttonwillow Dec. 4.
Paul; we connected the roll cage to the shock towers at all four corners with triangulation, then connected the rear shock towers to the trans mounts in the rear trunk, and connected that rear beam to the suspension ear under the car. I don't have pictures but if you're interested I'll take some. What are you going to do after you cut out the firewall? |
URY914 |
Nov 9 2004, 10:52 AM
QUOTE(drew365 @ Nov 9 2004, 08:27 AM) What are you going to do after you cut out the firewall? I'm going to run bars from the rear towers stright to the main hoops outside vertical bars. Than run diagonals from each shock tower to the diagonal of the main hoop. This would be over the engine. Than run a bar from the hoop diagonal to the front hoop. Sorta hard to explain... (IMG:style_emoticons/default/sad.gif) The fire wall will be removal made from aluminum or f/g. Paul |
blabla914 |
Nov 9 2004, 11:00 AM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
Where's that shivering smilely? Where is there an autocross in CT this weekend? Kelly |
Part Pricer |
Nov 9 2004, 11:55 AM
QUOTE(blabla914 @ Nov 9 2004, 12:00 PM) Where is there an autocross in CT this weekend? Kelly In Waterbury. The info is here: http://fcscc.com/04schedule.htm |
kermit |
Nov 9 2004, 12:01 PM
Member Group: Members Posts: 169 Joined: 2-November 04 From: Millbrae, CA Member No.: 3,049 |
Over the weekend, just pulled off the worn stickies and put on the stock Fuchs with some 70-series tires. I think the car sits about 1.5 to 2 inches higher! Took off the race numbers and washed to car. Its now hibernating in the garage with a cover over it.
Sleep tight sweet Kermit. We'll play some more in the spring after daddy gets you a new set of shoes. |
URY914 |
Nov 9 2004, 12:21 PM
QUOTE(mike_the_man @ Nov 9 2004, 07:51 AM) I'm also in the middle of gutting and remodeling my basement, so who knows how much car stuff will get done. I told my wife I was going to pull the engine out and her reply was, "After you finish the kitchen, right?" What would I do without her? or should I say, What I COULD do without her... (IMG:style_emoticons/default/wub.gif) Paul |
3d914 |
Nov 9 2004, 02:00 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Not jack stands yet . . . (IMG:style_emoticons/default/driving.gif)
You guys should come over to Phoenix. We're only into our 3rd AutoX for the season. In fact we have a Drivers Ed coming up the 21st of Nov. at Firebird East. Enjoy! |
qa1142 |
Nov 9 2004, 03:02 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
UP LAST WEEKEND. LONG LIST TILL APRIL (IMG:style_emoticons/default/clap56.gif)
nebreitling |
Nov 9 2004, 03:10 PM
jackstand season came early for me this year!
(IMG:style_emoticons/default/sad.gif) engine drop and replacement, with a case of W.I.I.T. (while i'm in there)... it's alright, just a few more weeks and i should be back on the road. perfect for the rainy season! (IMG:style_emoticons/default/sad.gif) |
nynone4 |
Nov 9 2004, 03:18 PM
Hammer to fit. Paint to match. Group: Members Posts: 353 Joined: 20-May 03 From: East Peoria, Illinois Member No.: 713 Region Association: None |
Mine's been there since the beginning of October - for bodywork, subtle rear flares and a paint job.
roundboy914 |
Nov 9 2004, 04:24 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
Hey Nynone4,
Who are you having paint your car? I am on the SW suburbs, and am looking to have my 914 painted, and am looking for recomendations. And mine is on jackstands, with a small list of things to accomplisg this winter. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:28 AM |
