draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
Hi guys,
I got a few "blank" carbon fiber bike parts that I would like to paint with color rite.com paint (red and clear). Do I need a special primer, just like for plastic parts, or is it "just" prep, red and clear. Thanks, Dragan |
wingnut86 |
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States ![]() |
PM Ruby914.
He's a CF pro... |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,106 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
...and once you PM the person who knows, tell us all! It's a forum. Let's share the information!
ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
Hi Dragan,
I sand all the excess resin from CF, clean and paint directly with automotive clear coat. Any excess resin will oxidize and get that dingy yellow look. If your painting it red you don't have to worry about the oxidation. I was not familiar with color rite paint. I took a look at their site, they have a primer that should work fine. You don't need anything special but a good primer can't hurt. Mike |
draganc |
Hi Dragan, I sand all the excess resin from CF, clean and paint directly with automotive clear coat. Any excess resin will oxidize and get that dingy yellow look. If your painting it red you don't have to worry about the oxidation. I was not familiar with color rite paint. I took a look at their site, they have a primer that should work fine. You don't need anything special but a good primer can't hurt. Mike Thanks Mike! I'm think of masking off "ducati" before applying the red and cover all with clear. I guess I'll just skip the primer. As in regards to colorrite, that's the only company I found that sells Ducati matching paint. Any suggestions about alternative sources? Dragan |
draganc |
Ps: also thanks for the tip wignut86
ruby914 |
I presumed by "blank" CF parts you meant they were unfinished, to what extent I was not sure. It sounds like they may have come with a gloss over all including over "ducati"? Painting over any gloss surface you will need to scuff it up to give the paint bite.
Just as long as you prep well with a quality paint you should be OK with out primer. |
Lo-Fi Version | Time is now: 19th July 2025 - 01:17 AM |
