Start of, 5 lug conversion |
billh1963 |
Jan 10 2013, 03:15 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Beech chair and furniture dolly. My poor mans creeper. (IMG:style_emoticons/default/lol-2.gif) Problem is when I recline it back there is a danger of... (IMG:style_emoticons/default/yellowsleep[1].gif) That is awesome! (IMG:style_emoticons/default/biggrin.gif) |
Eric_Shea |
Jan 10 2013, 05:54 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Friggin Hilarious... where's the cup holder? (IMG:style_emoticons/default/confused24.gif)
bigkensteele |
Jan 10 2013, 07:22 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Beech chair and furniture dolly. My poor mans creeper. (IMG:style_emoticons/default/lol-2.gif) Problem is when I recline it back there is a danger of... (IMG:style_emoticons/default/yellowsleep[1].gif) That's fantastic! (IMG:style_emoticons/default/beer.gif) If HF get's hold of that picture, they might just patent your idea out from under you and start selling a chair and dolly as a kit. |
SUNAB914 |
Jan 11 2013, 11:16 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Glad you posted this, I will be following your process for mine one day. If I ever get another car and get the wrecked one out of my garage.
Elliot Cannon |
Jan 15 2013, 07:54 PM
Here. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Elliot Cannon |
Jan 15 2013, 07:56 PM
Getting the left front side taken apart. So far, so, so-so. (IMG:style_emoticons/default/biggrin.gif) Maybe some new tie-rods. Or at least some new boots.
Elliot Cannon |
Jan 15 2013, 08:00 PM
Nice to have the correct tools. I don't often use this but when I need it I really, really need it. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif)
Elliot Cannon |
Jan 15 2013, 08:03 PM
These are off to the races. Or rather getting new races pressed in. (IMG:style_emoticons/default/biggrin.gif)
Elliot Cannon |
Jan 15 2013, 08:06 PM
These just came in the mail. Veeerrrry niiiiice. Thanks Eric.
Eric_Shea |
Jan 15 2013, 11:10 PM
Who does your nails? (IMG:style_emoticons/default/confused24.gif) |
euro911 |
Jan 16 2013, 01:11 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Making a little more progress. I got the left rear trailing arm off and am replacing rear wheel bearings and "while I'm in there", trailing arm bushings. The old bushings came out really easy, compared to the original rubber ones I replaced about 10 years ago. (IMG:style_emoticons/default/biggrin.gif) Probably get the left side installed before taking the right side apart. I find it easier to do it that way. Elliot, you may want to consider a more stable support for the car than that lawn chair under the muffler. (IMG:style_emoticons/default/beerchug.gif) |
Eric_Shea |
Jan 16 2013, 09:24 AM
Spoke |
Jan 16 2013, 10:50 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Nice rear calipers. Are these for vented rotors?
mittelmotor |
Jan 16 2013, 11:35 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Yeah. It'd be a bad omen for the aircraft manufacturer to spell its name "Beachcraft"! (IMG:style_emoticons/default/biggrin.gif) |
Elliot Cannon |
Jan 16 2013, 01:27 PM
Making a little more progress. I got the left rear trailing arm off and am replacing rear wheel bearings and "while I'm in there", trailing arm bushings. The old bushings came out really easy, compared to the original rubber ones I replaced about 10 years ago. (IMG:style_emoticons/default/biggrin.gif) Probably get the left side installed before taking the right side apart. I find it easier to do it that way. Elliot, you may want to consider a more stable support for the car than that lawn chair under the muffler. (IMG:style_emoticons/default/beerchug.gif)Hi! I'm Elliot and I'm a narpoleptic. (IMG:style_emoticons/default/smoke.gif) |
Eric_Shea |
Jan 16 2013, 06:12 PM
Nice rear calipers. Are these for vented rotors? Si. See... http://www.pmbperformance.com/catalog/item...552/9663436.htm |
Spoke |
Jan 16 2013, 06:31 PM
Nice rear calipers. Are these for vented rotors? Si. See... http://www.pmbperformance.com/catalog/item...552/9663436.htm Thanks, those calipers look fantastic. (IMG:style_emoticons/default/hijacked.gif) Eric, So one can use 4.5mm spacer under the rotor (like I did) or spacers under the caliper ears? If spacers under the caliper ears, will the rotor hit the rock shield? Also does the rock shield bracket still go under the caliper ears or just use smaller spacers? Sorry for the questions. I'm not satisfied with the centering of the rotors when using the spacer under the rotors. Even with the small hold-down screws, there is a lot of play in the rotor and I need to use my run-out gauge to properly center the rotor. It is very time consuming and if the screws loosen (there's no lock washers and I didn't use thread lock), the rotors will go out of center when the wheel is removed and will need adjusted. There has to be a better way to mount the rotors. I like the idea of moving the calipers back vs. the spacer under the rotor. Maybe we should take this topic off line. |
Elliot Cannon |
Jan 16 2013, 07:33 PM
Elliot Cannon |
Jan 16 2013, 07:38 PM
Someone said "necessity is the Mother of invention". And pressing my trailing arm bushings in was a "Mother"!! I had to "invent" a press with some wood blocks, large sockets, an 8 foot length of square tubing and my lift. It actually worked. (IMG:style_emoticons/default/lol-2.gif)
mittelmotor |
Jan 16 2013, 07:42 PM
Someone said "necessity is the Mother of invention". And pressing my trailing arm bushings in was a "Mother"!! I had to "invent" a press with some wood blocks, large sockets, an 8 foot length of square tubing and my lift. It actually worked. (IMG:style_emoticons/default/lol-2.gif) Nice! Usually the trailing arm flies across the garage a couple of times. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:06 AM |
