QUOTE(Eric_Shea @ Jan 16 2013, 07:12 PM)
QUOTE(Spoke @ Jan 16 2013, 09:50 AM)
Nice rear calipers. Are these for vented rotors?
Si.
See...
http://www.pmbperformance.com/catalog/item...552/9663436.htmThanks, those calipers look fantastic.
Eric,
So one can use 4.5mm spacer under the rotor (like I did) or spacers under the caliper ears?
If spacers under the caliper ears, will the rotor hit the rock shield?
Also does the rock shield bracket still go under the caliper ears or just use smaller spacers?
Sorry for the questions. I'm not satisfied with the centering of the rotors when using the spacer under the rotors. Even with the small hold-down screws, there is a lot of play in the rotor and I need to use my run-out gauge to properly center the rotor. It is very time consuming and if the screws loosen (there's no lock washers and I didn't use thread lock), the rotors will go out of center when the wheel is removed and will need adjusted.
There has to be a better way to mount the rotors. I like the idea of moving the calipers back vs. the spacer under the rotor.
Maybe we should take this topic off line.
