Start of, 5 lug conversion |
Elliot Cannon |
Jan 3 2013, 08:27 PM
I thought since the holidays are over, maybe I should start a new project with the car. I haven't done much to it in about 8 years. So. I'm in for it now. I hope the long. and the jack pad look as good on the pax side. (IMG:style_emoticons/default/smile.gif)
Ferg |
Jan 3 2013, 08:36 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
bigkensteele |
Jan 3 2013, 08:39 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Is that an oil cooler in front of the muffler with the hose duct leading to it?
Sorry to go off-topic, just curious. |
76-914 |
Jan 3 2013, 08:59 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Oh God, (IMG:style_emoticons/default/poke.gif) I worry when I see you with a screwdriver in your hand. Should I put EMS on alert. (IMG:style_emoticons/default/happy11.gif) And Bill, yes that is ducted air from a NACA vent on his side valence. IIRC, He wrote about it in a remote oil cooler posts recently.
EdwardBlume |
Jan 3 2013, 09:02 PM
You of all people need a 914 on jackstands! Mach 0. (IMG:style_emoticons/default/lol-2.gif)
Elliot Cannon |
Jan 3 2013, 10:51 PM
These. Attached image(s) |
Spoke |
Jan 4 2013, 09:34 AM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
What are you using for the 5-lug suspension?
Re-drilled rear hubs? 911 front end? |
brant |
Jan 4 2013, 09:37 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
good looking wheels!
Elliot Cannon |
Jan 4 2013, 12:38 PM
MoveQik |
Jan 4 2013, 02:14 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
You gonna have to pull the fenders a little?
Spoke |
Jan 4 2013, 04:31 PM
911 front struts. 914/6 stub axles. Vented rotors. Nice! Vented rotors in the rear? What year 911 front? 3 or 3.5inch calipers? How wide are those wheels? I just went through my 2nd 5-lug conversion. One of the most funnest upgrades. Takes our little cars further from being a NARP and closer to being a real Porsche. Plus the big boy wheels really look good on the car. |
proto31 |
Jan 4 2013, 04:42 PM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
Nice Elliot! Good to know that you're working on your car. When does the Chalon kit arrive? Is it coming over with the V6 you're installing?
Elliot Cannon |
Jan 4 2013, 05:51 PM
Elliot Cannon |
Jan 4 2013, 06:00 PM
Nice Elliot! Good to know that you're working on your car. When does the Chalon kit arrive? Is it coming over with the V6 you're installing? I've always loved the look of the Chalon kit. Till I tracked down the maker of this kit and he agreed to make one for my car. I think $15,000 is a pretty good price installed. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Elliot Cannon |
Jan 4 2013, 06:04 PM
911 front struts. 914/6 stub axles. Vented rotors. Nice! Vented rotors in the rear? What year 911 front? 3 or 3.5inch calipers? How wide are those wheels? I just went through my 2nd 5-lug conversion. One of the most funnest upgrades. Takes our little cars further from being a NARP and closer to being a real Porsche. Plus the big boy wheels really look good on the car. I'm not sure what year the front struts are from but the caliper mount bolt holes are 3 1/2 inches. The wheels are 7 1/2 and 10 X 17. |
Elliot Cannon |
Jan 9 2013, 08:01 PM
Making a little more progress. I got the left rear trailing arm off and am replacing rear wheel bearings and "while I'm in there", trailing arm bushings. The old bushings came out really easy, compared to the original rubber ones I replaced about 10 years ago. (IMG:style_emoticons/default/biggrin.gif) Probably get the left side installed before taking the right side apart. I find it easier to do it that way.
bigkensteele |
Jan 9 2013, 09:07 PM
Making a little more progress. I got the left rear trailing arm off and am replacing rear wheel bearings and "while I'm in there", trailing arm bushings. The old bushings came out really easy, compared to the original rubber ones I replaced about 10 years ago. (IMG:style_emoticons/default/biggrin.gif) Probably get the left side installed before taking the right side apart. I find it easier to do it that way. Elliot, you may want to consider a more stable support for the car than that lawn chair under the muffler. (IMG:style_emoticons/default/beerchug.gif) |
tscrihfield |
Jan 9 2013, 09:14 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Making a little more progress. I got the left rear trailing arm off and am replacing rear wheel bearings and "while I'm in there", trailing arm bushings. The old bushings came out really easy, compared to the original rubber ones I replaced about 10 years ago. (IMG:style_emoticons/default/biggrin.gif) Probably get the left side installed before taking the right side apart. I find it easier to do it that way. Elliot, you may want to consider a more stable support for the car than that lawn chair under the muffler. (IMG:style_emoticons/default/beerchug.gif) Ahahahahahaha (IMG:style_emoticons/default/lol-2.gif) Ken (IMG:style_emoticons/default/slap.gif) |
Eric_Shea |
Jan 10 2013, 07:58 AM
Elliot on the bench!
New 914-6/GT calipers loaded with Porterfield pads... (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1357826325.1.jpg) |
Elliot Cannon |
Jan 10 2013, 03:10 PM
Making a little more progress. I got the left rear trailing arm off and am replacing rear wheel bearings and "while I'm in there", trailing arm bushings. The old bushings came out really easy, compared to the original rubber ones I replaced about 10 years ago. (IMG:style_emoticons/default/biggrin.gif) Probably get the left side installed before taking the right side apart. I find it easier to do it that way. Elliot, you may want to consider a more stable support for the car than that lawn chair under the muffler. (IMG:style_emoticons/default/beerchug.gif) Beech chair and furniture dolly. My poor mans creeper. (IMG:style_emoticons/default/lol-2.gif) Problem is when I recline it back there is a danger of... (IMG:style_emoticons/default/yellowsleep[1].gif) Attached image(s) |
Lo-Fi Version | Time is now: 21st May 2024 - 09:18 AM |
