lightweight battery? |
siverson |
Jan 6 2013, 10:03 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Has anyone used a lightweight battery in the stock location? Which one did you choose? Any mounting tips?
I was thinking of one of these: http://www.odysseybattery.com/extremespecs.html -Steve |
carr914 |
Jan 6 2013, 10:05 PM
Racer from Birth Group: Members Posts: 118,774 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I had one mounted in the Rear Trunk - no problems
ConeDodger |
Jan 6 2013, 10:07 PM
Apex killer! Group: Members Posts: 23,598 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I used the extreme 20. It lasted about two years each time (I had two). I got a SS mount and put it in the stock location. I've got the mount around here somewhere...
0396 |
Jan 6 2013, 10:19 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I have their #35 / -pc 925 in my 996 for the past 3 months hooked up to a trickle charger...so far no concerns.
hotlanta914 |
Jan 6 2013, 10:41 PM
Newbie Group: Members Posts: 21 Joined: 15-July 06 From: Atlanta, GA Member No.: 6,438 |
I am using their PC 925 MJT - weighs in at 24 lbs. I purchased a plastic hold down strap that came with 2 J bolts, wing nuts and washers from Odyssey as well - the set-up seems to work well
MrLeeS |
Jan 6 2013, 10:47 PM
Member Group: Members Posts: 62 Joined: 25-April 09 From: Albuquerque, NM Member No.: 10,300 Region Association: Southwest Region |
I am using their PC 925 MJT - weighs in at 24 lbs. I purchased a plastic hold down strap that came with 2 J bolts, wing nuts and washers from Odyssey as well - the set-up seems to work well I've run a pc680 for years. Similar to the extreme 25 in dimensions. Haven't had any problems in a daily driver. Never stranded me. I've installed a couple in -6 and -4 track cars. No issues with those either. I would recommend using a trickle charger on cars less frequently driven to guard against parasitic drains. Once you kill them dead they are hard to recover. |
mskala |
Jan 7 2013, 11:15 AM
Solution I had for the PC680 (don't know what that equates to in your
pdf) was to get their mount, make a plate the exact size of the bottom of the stock tray and screw them together, battery lays on its side. Plate is held down by the stock screw and by the tabs on the other side. |
stugray |
Jan 7 2013, 03:21 PM
I am using the Braille light weight race battery.
Its dimensions are perfect to lay the battery down on it's side (sealed Battery so that is OK), and use a modified hold down bracket and you do not need to modify the stock battery tray. I have not used the battery yet (race car), but it fits perfectly in the stock location. Stu |
hotlanta914 |
Jan 7 2013, 04:38 PM
This my set-up
Attached thumbnail(s) |
Woody |
Jan 7 2013, 08:43 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I'm running a Braille 9 pound on its side in the stock location. It likes a maintainer capable of AGM batteries if left for a few weeks. Hasn't failed to start yet.
siverson |
Jan 7 2013, 09:41 PM
Thanks for the tips!
mtndawg |
Jan 8 2013, 11:27 AM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
siverson |
Feb 20 2013, 01:26 PM
Hmmm, so my "new" battery came, but the manufacture date is almost 2 years ago. That's strange, isn't it?
-Steve Attached thumbnail(s) |
wndsrfr |
Feb 20 2013, 08:55 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Hmmm, so my "new" battery came, but the manufacture date is almost 2 years ago. That's strange, isn't it? -Steve They claim a shelf life of 10 years along with other mil spec items.... I just ordered a PC680 from a distributor in Winchester, VA....will be interesting to see the manufacture date--should be here tomorrow. |
wndsrfr |
Feb 21 2013, 05:59 PM
Hmmm, so my "new" battery came, but the manufacture date is almost 2 years ago. That's strange, isn't it? -Steve OK...got mine today, a pc650 with "1212" on the label.....guess that means December...I'll try too attach a pic....got it from "Battery Mart" & it was shipped from Winchester, Va. Attached thumbnail(s) |
mskala |
Feb 21 2013, 07:16 PM
I just got one from ebay seller advantagebatt2. PC680. Looks current.
My old one is not even showing any signs of problems yet but want to avoid downtime. |
Lo-Fi Version | Time is now: 25th May 2024 - 12:44 AM |
