siverson
Jan 6 2013, 10:03 PM
Has anyone used a lightweight battery in the stock location? Which one did you choose? Any mounting tips?
I was thinking of one of these:
http://www.odysseybattery.com/extremespecs.html-Steve
carr914
Jan 6 2013, 10:05 PM
I had one mounted in the Rear Trunk - no problems
ConeDodger
Jan 6 2013, 10:07 PM
I used the extreme 20. It lasted about two years each time (I had two). I got a SS mount and put it in the stock location. I've got the mount around here somewhere...
0396
Jan 6 2013, 10:19 PM
I have their #35 / -pc 925 in my 996 for the past 3 months hooked up to a trickle charger...so far no concerns.
hotlanta914
Jan 6 2013, 10:41 PM
I am using their PC 925 MJT - weighs in at 24 lbs. I purchased a plastic hold down strap that came with 2 J bolts, wing nuts and washers from Odyssey as well - the set-up seems to work well
MrLeeS
Jan 6 2013, 10:47 PM
QUOTE(hotlanta914 @ Jan 6 2013, 09:41 PM)
I've run a pc680 for years. Similar to the extreme 25 in dimensions. Haven't had any problems in a daily driver. Never stranded me. I've installed a couple in -6 and -4 track cars. No issues with those either. I would recommend using a trickle charger on cars less frequently driven to guard against parasitic drains. Once you kill them dead they are hard to recover.
mskala
Jan 7 2013, 11:15 AM
Solution I had for the PC680 (don't know what that equates to in your
pdf) was to get their mount, make a plate the exact size of the
bottom of the stock tray and screw them together, battery lays on its
side. Plate is held down by the stock screw and by the tabs on the
other side.
stugray
Jan 7 2013, 03:21 PM
I am using the Braille light weight race battery.
Its dimensions are perfect to lay the battery down on it's side (sealed Battery so that is OK), and use a modified hold down bracket and you do not need to modify the stock battery tray.
I have not used the battery yet (race car), but it fits perfectly in the stock location.
Stu
hotlanta914
Jan 7 2013, 04:38 PM
This my set-up
Woody
Jan 7 2013, 08:43 PM
I'm running a Braille 9 pound on its side in the stock location. It likes a maintainer capable of AGM batteries if left for a few weeks. Hasn't failed to start yet.
siverson
Jan 7 2013, 09:41 PM
Thanks for the tips!
mtndawg
Jan 8 2013, 11:27 AM
QUOTE(hotlanta914 @ Jan 7 2013, 02:38 PM)
This my set-up
This looks nice. Why would you want the kill switch on the positive side of the battery? Doesn't it normally go on the negative side?
siverson
Feb 20 2013, 01:26 PM
Hmmm, so my "new" battery came, but the manufacture date is almost 2 years ago. That's strange, isn't it?
-Steve
wndsrfr
Feb 20 2013, 08:55 PM
QUOTE(siverson @ Feb 20 2013, 11:26 AM)
-Steve
They claim a shelf life of 10 years along with other mil spec items....
I just ordered a PC680 from a distributor in Winchester, VA....will be interesting to see the manufacture date--should be here tomorrow.
wndsrfr
Feb 21 2013, 05:59 PM
-Steve
OK...got mine today, a pc650 with "1212" on the label.....guess that means December...I'll try too attach a pic....got it from "Battery Mart" & it was shipped from Winchester, Va.
mskala
Feb 21 2013, 07:16 PM
I just got one from ebay seller advantagebatt2. PC680. Looks current.
My old one is not even showing any signs of problems yet but want
to avoid downtime.
