| Mark Henry |
Jan 8 2013, 10:30 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I have a set of struts sold to me as 911T struts. But mrHyde pointed out to me that they are a 914/6 number.
So were Boge part # 914 341 091 struts used on 911T's? I have everything for this conversion, but I'm going to have to buy new balljoints |
| Cap'n Krusty |
Jan 8 2013, 11:59 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I have a set of struts sold to me as 911T struts. But mrHyde pointed out to me that they are a 914/6 number. So were Boge part # 914 341 091 struts used on 911T's? I have everything for this conversion, but I'm going to have to buy new balljoints That's not a good number. If they take the early ball joints, I'd look for later struts. If the early ones aren't worn out now, they will be soon. The Cap'n |
| toolguy |
Jan 8 2013, 12:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
Yes, that is a good part number. 914-341-091-00 . it is for the left side on an 914-6. . and -092-00 is for the right side . and they were Boge. . . if it ended in a -34 then it was a Bilstein and was optional for 4 cylinder cars. . . but only the -00 was listed as available for sixs. .
AFAIK, it is the same "M" strut as the "T" strut but that carried a 911 part number. . they both used the small 3 inch 911T calipers. . For 1970, they both had the pinch bolt for the ball joint . . . Later struts had the wedge pin. . |
| Mark Henry |
Jan 8 2013, 01:40 PM
I have a set of struts sold to me as 911T struts. But mrHyde pointed out to me that they are a 914/6 number. So were Boge part # 914 341 091 struts used on 911T's? I have everything for this conversion, but I'm going to have to buy new balljoints That's not a good number. If they take the early ball joints, I'd look for later struts. If the early ones aren't worn out now, they will be soon. The Cap'n Are early ball joints bad? or the struts (which look good)? I know I would have to change the BJ's, but even though the old ones (1974, 75k miles in good condition) seem OK they could be the originals. I'm using the aluminium Brembo's with the 3" spacing. Yes, that is a good part number. 914-341-091-00 . it is for the left side on an 914-6. . and -092-00 is for the right side . and they were Boge. . . if it ended in a -34 then it was a Bilstein and was optional for 4 cylinder cars. . . but only the -00 was listed as available for sixs. . AFAIK, it is the same "M" strut as the "T" strut but that carried a 911 part number. . they both used the small 3 inch 911T calipers. . For 1970, they both had the pinch bolt for the ball joint . . . Later struts had the wedge pin. . Yes 914-341-091-00 and 914-341-092-00 |
| Eric_Shea |
Jan 8 2013, 01:46 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
No... Early balljoints aren't bad.
There have been instances where the bottom has ovaled out. I've "never" seen this first hand and, if installed properly would be pretty damn hard to do. For some reason (an old article in Pano) they continue to get a bad rap. To answer the question; they are the same but they don't have the same part number for some reason. Suspensions were installed as a complete units in 911s and 914s. I'm guessing the strut part number may have had something to do with the unit being loaded with 17mm torsion bars. |
| sixnotfour |
Jan 8 2013, 02:08 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,199 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
wedge bolt style cheaper manufacture
| Mark Henry |
Jan 8 2013, 02:31 PM
Thanks Eric,
Now I have another question Boge struts and I have Bilstein shocks. I can't see the part number on the '74 struts on my teen, IIRC it had Boge shocks originally, but it has been 10 years since I put the old stock bilstein's in. They are the Bilstein's with the huge chrome shafts and though they had a different cap they fit in no problem. |
| Cap'n Krusty |
Jan 8 2013, 04:44 PM
Yes, that is a good part number. 914-341-091-00 . it is for the left side on an 914-6. . and -092-00 is for the right side . and they were Boge. . . if it ended in a -34 then it was a Bilstein and was optional for 4 cylinder cars. . . but only the -00 was listed as available for sixs. . AFAIK, it is the same "M" strut as the "T" strut but that carried a 911 part number. . they both used the small 3 inch 911T calipers. . For 1970, they both had the pinch bolt for the ball joint . . . Later struts had the wedge pin. . Well, without the "00" it's not a good number ........................ As for the ball joint attachment method, I had, before I closed up shop, a largish pile of worn out early struts. In some cases, the ball joints were bad, as well, but mostly the strut bases were just enlarged to the point the ball joint was no longer tight in the receptacle. Bad news. BTW, for those folks who need a pair of early 911 struts for small brakes, I have a nice pair here that are "excess to my needs". The Cap'n |
| MDG |
Jan 8 2013, 05:09 PM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Thanks Eric, Now I have another question Boge struts and I have Bilstein shocks. I can't see the part number on the '74 struts on my teen, IIRC it had Boge shocks originally, but it has been 10 years since I put the old stock bilstein's in. They are the Bilstein's with the huge chrome shafts and though they had a different cap they fit in no problem. I have Bilstein's in Boge struts. I just bought the ones deisgned to fit those struts. I could be wrong but . . . the Bilsteins designed for the Boge strut fit in them. The ones not designed specifically for Boge won't fit. |
| Mark Henry |
Jan 8 2013, 09:42 PM
No... Early balljoints aren't bad. There have been instances where the bottom has ovaled out. I've "never" seen this first hand and, if installed properly would be pretty damn hard to do. For some reason (an old article in Pano) they continue to get a bad rap. To answer the question; they are the same but they don't have the same part number for some reason. Suspensions were installed as a complete units in 911s and 914s. I'm guessing the strut part number may have had something to do with the unit being loaded with 17mm torsion bars. Checked the BJ mounting hole and it looks real good, not beat out, round and only a few thousands difference between top and bottom of the bore. they are real clean struts, I think I'm good. Thanks Eric, Now I have another question Boge struts and I have Bilstein shocks. I can't see the part number on the '74 struts on my teen, IIRC it had Boge shocks originally, but it has been 10 years since I put the old stock bilstein's in. They are the Bilstein's with the huge chrome shafts and though they had a different cap they fit in no problem. I have Bilstein's in Boge struts. I just bought the ones deisgned to fit those struts. I could be wrong but . . . the Bilsteins designed for the Boge strut fit in them. The ones not designed specifically for Boge won't fit. I think that's what I have as well. (IMG:style_emoticons/default/wink.gif) |
| sixnotfour |
Jan 8 2013, 09:50 PM
Bils' should go in and tighten up fine.
Lo-Fi Version | Time is now: 15th April 2026 - 11:09 PM |
