Headlight filler plate question |
Peashooter |
Jan 10 2013, 06:30 PM
Member Group: Members Posts: 164 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
Hi Guys,
I'm installing the headlights into my six, and I have a question about how the filler plates in front of the headlights get installed. I have the rubber pieces, but being as how the car was completely stripped when I got it, I don't know how they go in correctly. The factory manual is no help and I know you guys know how to do it. Pictures are always appreciated, but verbiage will work as well.Thanks! Bill |
toolguy |
Jan 10 2013, 08:37 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
IIRC-remove the headlight plastic surrounds. . If you've got small hands you can reach inside under the eyelids without pulling the headlights out . . the little rubber plugs push through, pointy side out, 1 to under the fender and 2 inside the trunk. . . lube them up. . push. . . and use a little 'pick' to work them through. . . Yeah, it's somewhat of a PITA.
By the way. . where they go is where they go. . you adjust the gaps by adjusting the headlight hinge pins |
Jan 10 2013, 08:50 PM
Whatever you do, make sure you have both headlight relays removed first!
Your fingers will thank you ... (IMG:style_emoticons/default/shades.gif) |
Peashooter |
Jan 11 2013, 09:28 AM
Whatever you do, make sure you have both headlight relays removed first! Your fingers will thank you ... (IMG:style_emoticons/default/shades.gif) Thanks, I've got it. No need to worry about relays yet, the car is just now coming together. I used a motorcycle battery to test things and get the final adjustments right. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:50 AM |
