Car I looked at in Hillsboro - The guy wanted to sell me his 914, Not a bad looking car but problems |
Mikey914 |
Jan 11 2013, 11:59 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'm posting this as a courtesy for those who may be looking. The car wil lprobably pop up on Craigslist in a few weeks. I didn't want to put in tthe clasifieds as I don't want to be involved, but did want to post what I saw.
He says it's a 73. The engine has a single carb set up, I couldn't see the bottom stud layout, but only felt 1 bolt so i believe it to be a 2.0. It has fiberglass flairs, 5 bolt lug set up with 944 wheels. It has a rear deck lid that is cracking loose at the bonded section. The front bumper is not mounted correctly, or at least the gap too far out. The flairs look good The interior looks good Unfortunately- It appears that there were some plates pop riveted to the floor (probably hiding rust, but at least not a correct repair). Also from the wheel well there was a section around the battery tray that was replaced and not sealed inside the wheel well. I suspect rust to be hiding in the long and rocker, The reat trunk as the usual rust with some nonstandard repairs. Seller wanted $6500, but way too many issues for me. He seemed to be flexable, but given the issues at hand I had no desire to counter. Hope this helps someone And yes I was stupid and didn't get the VIN. Items I did note- Early jack Late doors Early seatbelts Some money was spent on the car, but the execution could have been much better. Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:33 PM |
