> Timing question - plugging the vacuum advance hose
john_g
post Jan 11 2013, 04:15 PM
I have only had experience using John Muir's static timing method with VW's, so am not used to the strobe light procedure for the 914. So, I have a number of questions:
1) To get a starting point, using a static timing light or voltmeter, what's the static timing mark to use with a '74 2.0 engine - 5º or 7.5º?
2) Before using the strobe light, some instructions say to remove the vacuum hose from the distributor, others say to remove AND plug it with something. What's correct? And, if I plug it, do I plug the hose end or the connector to the distributor, or both? (IMG:style_emoticons/default/confused24.gif)
Thanks.
SLITS
post Jan 11 2013, 04:39 PM
"This Utah shit is HARSH!"
2.0L engine .... 27 degrees @ 3000 RPM** is what I use. No static numbers published as far as I know.
On a 74, there is only Vac Retard ... Vac Advance is not hooked up. You plug the line so that your idle doesn't go up from the vacuum leak you create. Plug the hose with a pen or pencil so that you don't have an open vac leak at the throttle body.
** Some say 3500 RPM, but as far as I am concerned, all mechanical advance should be in at 3000.
john_g
post Jan 11 2013, 04:58 PM
Thanks. So ... I only plug the hose end, not the connection to the distributor, right?
rmital
post Jan 11 2013, 05:13 PM
Northeast optimist
QUOTE(john_g @ Jan 11 2013, 05:58 PM) *
Correct, and I like to use a golf tee to plug the hose
SLITS
post Jan 11 2013, 05:40 PM
QUOTE(rmital @ Jan 11 2013, 03:13 PM) *
Sorry Ray ... I don't chase little white balls around a Cow Pasture ... (IMG:style_emoticons/default/smile.gif)
Dave_Darling
post Jan 11 2013, 07:52 PM
914 Idiot
Just use TDC as a static timing point; it should get you close enough for the engine to run.
With the D-jet system, you don't actually have to plug the vacuum line. It's good practice, though, since leaving it unplugged can cause problems with L-jet or carbs. It also keeps un-filtered air from getting into the engine, which can be nice if you live in a dusty area.
--DD
john_g
post Jan 13 2013, 04:37 PM
QUOTE(Dave_Darling @ Jan 11 2013, 05:52 PM) *
--DD
Thanks - that jives with the Haynes manual which just says to disconnect the hose and says nothing about plugging it.
last337
post Jan 13 2013, 05:11 PM
Where is the vacuum connection you guys are talking about? I have nothing going to my carbs or distributor but not sure where then original vacuum connection was. Any pics?
Dave_Darling
post Jan 13 2013, 05:44 PM
914 Idiot
We're talking specifically about D-jetronic fuel injection. Carbs are a different beast.
On the original injected motors, there was a vacuum dashpot on the side of the distributor. Most 914s had two hoses connected to the dashpot; one vacuum retard line that went from the fitting pointing toward the distributor body to the throttle body after the throttle plate, and the other a vacuum advance line that went from the fitting pointing away from the distributor body to the throttle body before the throttle plate.
Carbs usually don't have the fittings for either of those. And more often than not, the distributors are replaced when carb conversion is done so that the distributors don't have the vacuum dashpot either. So don't worry about them.
--DD
last337
post Jan 13 2013, 07:04 PM
QUOTE(Dave_Darling @ Jan 13 2013, 05:44 PM) *
--DD
Thanks for reply. I was wondering what the spot is for a hose next to the #2 spark plug. I don't have anything plugged in there but looks like something should go there
Dave_Darling
post Jan 13 2013, 09:37 PM
914 Idiot
The #2 plug? That doesn't sound familiar. Is it on the carb manifold, or coming out of the head, or something else? If it's coming out of the head, then it's for the Positive Crankcase Ventilation system.
--DD
last337
post Jan 14 2013, 09:47 AM
QUOTE(Dave_Darling @ Jan 13 2013, 09:37 PM) *
--DD
I was talking about this one right next to that with the braided hose on it. That hose doesnt appear to go anywhere after that. It just goes into the cover it looks like.
- Lo-Fi Version Time is now: 15th March 2026 - 02:59 PM
