mittelmotor gearstack build |
Dr Evil |
Jan 12 2013, 09:47 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I love rebuilding gear stacks. They are cleaner, cheaper, and faster to do. This one arrived this afternoon for a disassemble, inspect, repair and gearing change. On the surface all of the parts looked to be in great shape.....after parting it I found a busted main bearing and two broken thrust blocks.
Note the sectioned ball retainer. No-go. Note the intact block on the right and the two broken ones. |
914Sixer |
Jan 12 2013, 10:08 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
UGH !!!
Black22 |
Jan 12 2013, 10:26 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/blink.gif) WOW! No wonder my 1911 was faster than his LS1 on our New Years run!!! (IMG:style_emoticons/default/av-943.gif)
Glad your fixing it up for him! (IMG:style_emoticons/default/aktion035.gif) |
Dr Evil |
Jan 12 2013, 10:33 PM
Ya, the blocks being broke would make shifting suck. The new gearing ought to wake the car up (IMG:style_emoticons/default/smile.gif)
mrbubblehead |
Jan 12 2013, 10:39 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
With the new gears and bearing should the pinion depth be reset?
Dr Evil |
Jan 12 2013, 10:43 PM
Compensation for any thickness differences between the replacement gear and the original one need to be compensated for. However, there is almost always only negligible differences and this needs no compensation. If compensation is needed, you can either add to the gasket the difference you calculate, or mess with pinion shims. No need to get crazy with fully resetting.
Woody |
Jan 12 2013, 10:49 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
The thrust blocks are only broke on one side. Cant you just turn them over?
mrbubblehead |
Jan 12 2013, 11:03 PM
Compensation for any thickness differences between the replacement gear and the original one need to be compensated for. However, there is almost always only negligible differences and this needs no compensation. If compensation is needed, you can either add to the gasket the difference you calculate, or mess with pinion shims. No need to get crazy with fully resetting. Gotcha, i'm trying to learn all I can. |
Spoke |
Jan 12 2013, 11:16 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The main bearing in my sideshift was also busted when you rebuilt it.
The Evil rebuilt trans still shifts like brand new. (IMG:style_emoticons/default/smilie_pokal.gif) |
Dr Evil |
Jan 12 2013, 11:38 PM
The thrust blocks are only broke on one side. Cant you just turn them over? We need a facepalm smiley for these people (IMG:style_emoticons/default/dry.gif) No, Woodrow. Now take your meds. |
oldschool |
Jan 12 2013, 11:53 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Compensation for any thickness differences between the replacement gear and the original one need to be compensated for. However, there is almost always only negligible differences and this needs no compensation. If compensation is needed, you can either add to the gasket the difference you calculate, or mess with pinion shims. No need to get crazy with fully resetting. Gotcha, i'm trying to learn all I can. Man keep learning, We can use a good tranny guy on our side.(so ca.) (IMG:style_emoticons/default/aktion035.gif) |
mittelmotor |
Jan 13 2013, 12:07 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Cool! People have always said that I'm "special" ( I try to take that as a compliment) and it looks like it extends to my transaxle as well! Can't wait to get it back. (IMG:style_emoticons/default/piratenanner.gif)
Might the broken blocks have hindered the 2-3 shift? It was odd...it would make the shift just fine at low to medium revs, but refuse to engage at higher revs. --Doug |
Dr Evil |
Jan 13 2013, 12:27 AM
Nope. One of the blocks was in 1st and I forget which the other was in. Probably 2, 3, 4, or 5. (IMG:style_emoticons/default/biggrin.gif)
mittelmotor |
Jan 13 2013, 12:48 AM
But if the other broken block was in 2nd or 3rd gear, couldn't it mess up the 2-3 shift? I should note that even though I was able to pull the gearstack, my understanding of the inner workings is a little fuzzy. Maybe too much (IMG:style_emoticons/default/beer3.gif) consumed when watching your video. (IMG:style_emoticons/default/biggrin.gif)
Dr Evil |
Jan 13 2013, 08:48 AM
Yes, this could account for poor shifting.
mrbubblehead |
Jan 13 2013, 02:11 PM
Compensation for any thickness differences between the replacement gear and the original one need to be compensated for. However, there is almost always only negligible differences and this needs no compensation. If compensation is needed, you can either add to the gasket the difference you calculate, or mess with pinion shims. No need to get crazy with fully resetting. That is assuming that the pinion depth was correct to begin with right? Shouldn't that be confirmed? |
Dr Evil |
Jan 13 2013, 05:17 PM
No. No need to confirm, unless you have the expensive tools to do so, the time, the know how, and a reason.
Dr Evil |
Jan 19 2013, 05:39 PM
And the finished product before packing and shipping (IMG:style_emoticons/default/biggrin.gif)
mittelmotor |
Jan 19 2013, 08:48 PM
Thing of beauty, Mike! (IMG:style_emoticons/default/pray.gif)
Can't wait to plug it back in and go for a drive. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) Did those HBs look pretty good to you? |
Black22 |
Jan 19 2013, 10:11 PM
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/aktion035.gif)
You will be happy mittelmotor! Now maybe you'll be able to keep up with my 1911! (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 03:27 AM |
