Oil Temp sending unit |
K9Torro |
Nov 10 2004, 02:42 PM
Newbie Group: Members Posts: 21 Joined: 10-November 04 From: South Georgia Member No.: 3,083 |
I just bought a factory three gage appearance group console from someone on EPay, do I need to get a VDO oil temp sending unit to make the gage work or is there one already on my car someplace, I have a 1972 1.7 FI.
If I need to get one where does it go and how do I do it ? Thanks in advance, (IMG:style_emoticons/default/cool_shades.gif) |
Nov 10 2004, 03:28 PM
Resident German Group: Admin Posts: 41,633 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(K9Torro @ Nov 10 2004, 01:42 PM) I have a 1972 1.7 FI. probably not. the sending unit goes to what is commonly refered to as the "Taco Plate" ... it's a small round plate on the bottom of the motor that has the sender in the middle. motors that came without the sender simply had a black cover. (IMG:style_emoticons/default/wink.gif) Andy Attached image(s) |
Nov 10 2004, 03:29 PM
2nd
qa1142 |
Nov 10 2004, 03:32 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I'm still looking for one of these set-ups too. first quote is $50
I have WTB ad in clasifieds |
Joe Ricard |
Nov 10 2004, 03:35 PM
I'm kinda curious. I just thought I would try and see if the sender would fit the drain plug hole . (IMG:style_emoticons/default/idea.gif) I got one of each (drain plug hole and sender)will test tonight.
Nov 10 2004, 03:41 PM
QUOTE(Joe Ricard @ Nov 10 2004, 02:35 PM) I'm kinda curious. I just thought I would try and see if the sender would fit the drain plug hole . (IMG:style_emoticons/default/idea.gif) I got one of each (drain plug hole and sender)will test tonight. the sender is in a certain location for a reason ... even if it fit's, you won't get the same readings ... (IMG:style_emoticons/default/cool.gif) Andy |
morph |
Nov 10 2004, 03:47 PM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
yeah you bought that from me todd.
i have the plate and sending unit for it.ill give ya a deal on it.since none of the items have been tested.all of the parts are out of a 73 2.0 that was last licensed for the road in 2000. and welcome to the club james appearance & performance |
K9Torro |
Nov 10 2004, 04:00 PM
Hi James, Did you get my PayPal I sent it before I heard anything from you, I like to pay right away so I dont lose track of the auctions. I would like to have the plate and sending unit, can you send me an email or a PayPal invoice for it ? Todd
morph |
Nov 10 2004, 04:12 PM
i just e mailed you on it
ill get a invoice out to you (30.00) we will just throw it in the box with the console thanks james |
K9Torro |
Nov 10 2004, 04:13 PM
Thanks for the pictures and info Andy (IMG:style_emoticons/default/biggrin.gif)
K9Torro |
Nov 10 2004, 04:18 PM
James, new PayPal sent on the plate and sending unit. Thanks Todd (IMG:style_emoticons/default/boldblue.gif)
Joe Ricard |
Nov 10 2004, 08:44 PM
[quote=SirAndy,Nov 10 2004, 01:41 PM] [/QUOTE]
the sender is in a certain location for a reason ... even if it fit's, you won't get the same readings ... (IMG:style_emoticons/default/cool.gif) Andy [/quote] Uh bottom of the case is the bottom of the case. But no it don't fit. |
Nov 10 2004, 10:17 PM
QUOTE(Joe Ricard @ Nov 10 2004, 07:44 PM) Uh bottom of the case is the bottom of the case. But no it don't fit. nope, it's actually not ... look how the taco plate moves the sender deeper into the case. (IMG:style_emoticons/default/cool.gif) Andy |
Joe Ricard |
Nov 11 2004, 07:13 AM
Guess we need to be scientific about it. However I am not going to rethread my drain plug hole to conduct it and prove my point so I will have to let this one go.
ClayPerrine |
Nov 11 2004, 07:18 AM
Life's been good to me so far..... Group: Admin Posts: 15,454 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
QUOTE(Joe Ricard @ Nov 10 2004, 01:35 PM) I'm kinda curious. I just thought I would try and see if the sender would fit the drain plug hole . (IMG:style_emoticons/default/idea.gif) I got one of each (drain plug hole and sender)will test tonight. Would you really want it hanging down on the bottom of the motor like that? I know it's not lower than a tuna can, but you still take a chance of breaking the sender off with road debris. Plus, you would have to remove it to drain the oil, and you risk breaking it when unscrewing it. Personally, I think that it's better in the taco plate. |
Joe Ricard |
Nov 11 2004, 12:05 PM
Duh? I was just looking at a way around the taco plate for engines without them. Guess I will continue swapping plates with the engine being used.
MXMARK |
Nov 11 2004, 12:09 PM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
I could not find a taco plate plus the gauge that I have is from a 911 so I mounted a sender in the drain plug 0-150c and 12mm X 1.50mm VDO part #323 092D. The sender matches the 300f gauge perfectly. I would agree that the readings seem to change slow at first waiting for the case to heat up. and fast for stop and go and running down the freeway. When I stop and shut off the motor the gauge reads higher then while moving down the road even at higher rpm. Any one have a taco plate? Are the aftermarket ones done yet. Thanks Mark
Lo-Fi Version | Time is now: 12th May 2024 - 01:14 PM |
