Project Time! 71 garage build, Broke a Valve Spring... |
dfelz |
Jan 14 2013, 12:59 AM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
So today I bought a new shell for my project build, and I am extremely happy with my purchase! The body is in wonderful condition, perfectly straight, clean title, very minimal rust (and the rust it does have can be easily fixed without having to purchase RD pieces), and most importantly it was the right price (IMG:style_emoticons/default/first.gif)
Looks better in person but here are some pics. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1358146784.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1358146784.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1358146784.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1358146785.4.jpg) Already swapped on the tail lights from my 72 parts car (the one in the garage) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1358146785.5.jpg) Car has no front or rear windshield or engine/trans, but thats what parts cars are for. The car does have all the wiring in tact and non-molested, yay. So i have all of the parts needed to put this guy on the road plus lots of extras that will be added at a later point (one piece front fiberglass flared clip, rear 7" FG flairs, FG 911 dash with 5 gage pod..etc) If anyone was watching the thread called 20 year hibernation, you would see that i indeed got the little 1.7 to fire up, and idle nicely too, That wil be going in this beauty. So this week one of the tasks is to drop the engine and pop the top end off and take a look inside, hopefully it doesn't need too much work... I'm really excited now that I have a "rustless" roller to play with!! (IMG:style_emoticons/default/piratenanner.gif) |
dfelz |
Jan 19 2013, 02:14 PM
Ok thanks Mike, I think I will initially leave it off and if the time comes where i feel i need it i can always add it back on.
Next wiring question. On the 12 pin relay board harness, what is the white cable labeled Aux Air Valve? There is also a green with black stripe wire separating from the harness near the starter coil wires that was taped down by the PO, and its not on the relay board diagram. Anyone know what that is for? Shown in the picture are both the wires i am referring to (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1358626476.1.jpg) Thanks!! |
3d914 |
Jan 19 2013, 07:28 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Next wiring question. On the 12 pin relay board harness, what is the white cable labeled Aux Air Valve? Thanks!! David, The auxiliary air valve is the cold-start air source. It has a single 12v wire going to it. The air valve is mounted next to the air plenum (box) - forward & slightly left. I'll have to check my schematics to verify wire color. (Verified wire is white and comes from the 5-wire connector at the rear-right of the relay board) Making good progress. Keep it up. |
dfelz |
Jan 19 2013, 09:42 PM
Next wiring question. On the 12 pin relay board harness, what is the white cable labeled Aux Air Valve? Thanks!! David, The auxiliary air valve is the cold-start air source. It has a single 12v wire going to it. The air valve is mounted next to the air plenum (box) - forward & slightly left. I'll have to check my schematics to verify wire color. (Verified wire is white and comes from the 5-wire connector at the rear-right of the relay board) Making good progress. Keep it up. So if i have carbs and no air box i have no need for this wire correct? |
Lo-Fi Version | Time is now: 20th May 2024 - 10:27 PM |
