Oil pressure sender mounting |
brownaar |
Nov 10 2004, 05:23 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
I've got a 73 2.0 that I'm adding a dual oil pressure sender(gauge and idiot light) to. This thing is huge. Most of you know it won't fit through the opening for the single pole sender. My question is this? Has anyone used some type of extension(pipe or high pressure hose) with the proper threaded ends to hook one of these up to avoid cutting sheet metal and/or having to remove the distributor to have working space?
Thanks, Aaron |
Nov 10 2004, 05:28 PM
Resident German Group: Admin Posts: 41,633 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(brownaar @ Nov 10 2004, 04:23 PM) Has anyone used some type of extension(pipe or high pressure hose) with the proper threaded ends the original VDO kit came with a extension hose and a clamp to mount it ... (IMG:style_emoticons/default/wink.gif) Andy Attached image(s) |
brownaar |
Nov 10 2004, 05:38 PM
Anybody know if I can find one of these? That's exactly what I need.
Thanks, Aaron |
machina |
Nov 10 2004, 06:06 PM
aircooled.net
K9Torro |
Nov 10 2004, 09:12 PM
Newbie Group: Members Posts: 21 Joined: 10-November 04 From: South Georgia Member No.: 3,083 |
Hey where did you get that red dist cap and wires from ? (IMG:style_emoticons/default/boldblue.gif)
machina |
Nov 10 2004, 09:23 PM
QUOTE(K9Torro @ Nov 10 2004, 10:12 PM) Hey where did you get that red dist cap and wires from ? (IMG:style_emoticons/default/boldblue.gif) uh, aircooled.net (IMG:style_emoticons/default/smile.gif) and there is a unilte dizzy on the other end of that pretty red cap. |
MXMARK |
Nov 10 2004, 11:00 PM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
I have one a vdo kit or aircooled net. Thanks Mark
bperry |
Nov 10 2004, 11:08 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
And how do you guys tighten the end that goes down into the block?
What tool? With teflon? --- bill |
MXMARK |
Nov 10 2004, 11:21 PM
No teflon on the kit I made for my car the threads are tapered. I trhink the sender work better with a ground. I know the ground comes from the mount. 10mm by 1mm thread pitch tapered. Bend the right size wrench. This is a picture of my home made kit.
MXMARK |
Nov 10 2004, 11:26 PM
MXMARK |
Nov 10 2004, 11:28 PM
I changed the mount to the case so it would fit with the mallory I installed. see this link for more info. http://www.914world.com/bbs2/index.php?act...16433&hl=sender
brownaar |
Nov 11 2004, 07:52 AM
MXMARK,
You have a PM. Thanks, Aaron |
Lo-Fi Version | Time is now: 12th May 2024 - 01:10 PM |
