brownaar
Nov 10 2004, 05:23 PM
I've got a 73 2.0 that I'm adding a dual oil pressure sender(gauge and idiot light) to. This thing is huge. Most of you know it won't fit through the opening for the single pole sender. My question is this? Has anyone used some type of extension(pipe or high pressure hose) with the proper threaded ends to hook one of these up to avoid cutting sheet metal and/or having to remove the distributor to have working space?
Thanks,
Aaron
Nov 10 2004, 05:28 PM
QUOTE(brownaar @ Nov 10 2004, 04:23 PM)
the original VDO kit came with a extension hose and a clamp to mount it ...
Andy
brownaar
Nov 10 2004, 05:38 PM
Anybody know if I can find one of these? That's exactly what I need.
Thanks,
Aaron
machina
Nov 10 2004, 06:06 PM
aircooled.net
K9Torro
Nov 10 2004, 09:12 PM
Hey where did you get that red dist cap and wires from ?
machina
Nov 10 2004, 09:23 PM
QUOTE(K9Torro @ Nov 10 2004, 10:12 PM)
uh, aircooled.net
and there is a unilte dizzy on the other end of that pretty red cap.
MXMARK
Nov 10 2004, 11:00 PM
I have one a vdo kit or aircooled net. Thanks Mark
bperry
Nov 10 2004, 11:08 PM
And how do you guys tighten the end that goes down into the block?
What tool? With teflon?
--- bill
MXMARK
Nov 10 2004, 11:21 PM
No teflon on the kit I made for my car the threads are tapered. I trhink the sender work better with a ground. I know the ground comes from the mount. 10mm by 1mm thread pitch tapered. Bend the right size wrench. This is a picture of my home made kit.
MXMARK
Nov 10 2004, 11:26 PM
MXMARK
Nov 10 2004, 11:28 PM
I changed the mount to the case so it would fit with the mallory I installed. see this link for more info.
http://www.914world.com/bbs2/index.php?act...16433&hl=sender
brownaar
Nov 11 2004, 07:52 AM
MXMARK,
You have a PM.
Thanks,
Aaron
