plenum removal, '76 2.0 |
MarkG |
Nov 11 2004, 12:25 PM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
Is it held on with bolts that go through the 2 tubes either side of the TB? If so, what size bolts or are they screws? How to remove them/plenum?
I have an air leak somewhere and want to remove the plenum to check it's sealing. New: TB, TPS, CHT, MPS, injectors, FP regulator, FI points, dizzy breaker plate, cap rotor coil wires and plugs, manifold boots and gaskets and vacuum hoses. STILL wont idle for long, hunts and dies ......just like BEFORE I replaced all the above.... close to $2K in parts....carbs looking MIGHTY nice at this point now that Colorado is dropping emission tests...... |
2-OH! |
Nov 11 2004, 02:07 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Mark:
Before you go that far...I had the same problem, All I did (after 2 cans of spraying the entire engine bay for vacuum leaks) was unplug the temperature sensor on top of the plenum. It was bad...All my hunting and Idle problems went away... 2-OH! |
MarkG |
Nov 11 2004, 04:36 PM
cool will give it a try;
in all honesty I still have some routine things to check, and I still may be a bit off on the static timing. It does run strong while running though and I don't anticipate too much more work until it runs right. |
TheCabinetmaker |
Nov 11 2004, 04:52 PM
Vacuum leaks will cause a high idle. Hunting for idle could be a misadjusted CO level, but the tps must be adjusted properly for the co button to make much difference. A new tps should still be adjusted.
Lo-Fi Version | Time is now: 13th May 2024 - 06:07 AM |
