WTB - Side shift components, DONE |
dfelz |
Jan 21 2013, 01:30 AM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
I want to install my rebuilt side shift tranny in my 71 and need all the components to do the swap.
Need: Shift lever assembly Front shift Rod Firewall bushing (conversion type SLP-FSSC-001) Rear shift rod Rear shift rod bushing Shift console cover Engine mount bar to accommodate this setup Also need a throwout bearing PM, email, or reply to this thread if you have anything, please include pictures and asking price in your message. Interested in either new or used conditions parts (except for the bushings, only new) Thanks |
914ltd |
Jan 21 2013, 08:32 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
David, don't mess with the conversion firewall bushing. Use a tubing cutter to cut a 5" section out of the original (long) rod in the tunnel and weld or epoxy this on the rearmost of the late tunnel rod. The firewall bushing remains the stock 914-424-224-00 which is a 911 shift bushing that will always be available. If you are lucky enough to have a good firewall shift boot assembly, the photo shows the modified shift rod and all the parts you will need to do the conversion minus the drivers side warm air guide needed if you are using stock heats. The tunnel cover plate is to close the hole you will use to modify a bulkhead in the tunnel to clear the new shift rod travel. I also have good instructions. $350. plus ship. Brad
dfelz |
Jan 21 2013, 12:55 PM
Thanks Brad, at the moment I am discussing a package that Bruce (bdstone) has offered me that is similar to yours, he is local though so i wouldn't have to deal with shipping. I will keep you in mind though.
Thanks again for the quick reply and picture. |
Lo-Fi Version | Time is now: 16th May 2024 - 06:46 AM |
