New Paint and seal on the front access cover |
gunny |
Jan 21 2013, 10:31 AM
Member Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
In my quest to keep my car rust free as much as possible I cleaned up the front access panel. This is what I started with after removing the seal.
Attached thumbnail(s) |
gunny |
Jan 21 2013, 10:39 AM
Removed the paint and rust with a 3M wheel on my drill. Then finished it up by hand.
gunny |
Jan 21 2013, 10:40 AM
Added 2 coats of primer.
gunny |
2 Coats of Black
gunny |
Jan 21 2013, 10:42 AM
Put on the new rubber from 914Rubber and One less thing on my car that needs to be worked on.
IanS |
Jan 21 2013, 10:52 AM
Member Group: Members Posts: 83 Joined: 27-February 12 From: Edmond, Oklahoma Member No.: 14,190 Region Association: Southwest Region |
looks great! Never seen one that clean before...
jsayre914 |
Jan 21 2013, 10:54 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/cheer.gif) Nice Job
Tom_T |
Jan 21 2013, 11:06 AM
Looks nice Gunny!
Mikey914 |
Jan 21 2013, 12:14 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Nice job. Mind if I borrow your picture for the website. Unfortunately, I just used my car and didn't have a lot of time to clean it up pretty.
914Eric |
Jan 21 2013, 12:21 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Very nice job. OK...I'm a dummy...but where is this access cover? Since I have my car stripped down except for the center console I'm guessing behind the console? |
914itis |
Jan 21 2013, 12:48 PM
Under the car , covers the steering rack and gas tank access hole.
914Eric |
Jan 21 2013, 12:58 PM
Under the car , covers the steering rack and gas tank access hole. Ahhh...gas tank access. I took that one off. (IMG:style_emoticons/default/screwy.gif) Thanks Paul |
Tom |
Jan 21 2013, 04:46 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
gunny,
That's nice, until you put it back on and see how much the rest of the undercarriage needs similar work done!. (IMG:style_emoticons/default/smile.gif) Don't know when I will get to that! Not sure if I should take the undercoating off? Tom Attached thumbnail(s) |
gunny |
Jan 21 2013, 05:22 PM
I have started on the undercoating already. I'm doing a little at a time. I've already done the driver side front fenderwell and some of the driver floor. It is slow going, Ive been scraping it off with a screwdriver and putty knife. I've been lucky so far and haven't found anything but some small amount of surface rust.
I started the undercoating after completing the interior floor. I removed the tar then painted with por 15. I covered the floor with hushmat before putting the carpet back in. This is a long term project. (IMG:style_emoticons/default/ar15.gif) |
914outlaw |
Jan 21 2013, 05:28 PM
Dave Group: Members Posts: 198 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States |
Put on the new rubber from 914Rubber and One less thing on my car that needs to be worked on. Looks nice. (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Jan 22 2013, 12:32 AM
Looks like you could use at least front trunk drain tube.
Tom |
Jan 22 2013, 01:16 AM
Mikey,
Yes, (IMG:style_emoticons/default/smile.gif) along with engine bay seals, targa top seals, window seals, the list is long. One of these days I need to get in touch with you and determine all of my needs and get them all at once. Tom |
Mikey914 |
Jan 22 2013, 11:56 PM
You know I'll just keep making more (IMG:style_emoticons/default/biggrin.gif)
But yes, just let me know what you need. Thx |
Lo-Fi Version | Time is now: 21st May 2024 - 04:40 PM |
