gunny
Jan 21 2013, 10:31 AM
In my quest to keep my car rust free as much as possible I cleaned up the front access panel. This is what I started with after removing the seal.
gunny
Jan 21 2013, 10:39 AM
Removed the paint and rust with a 3M wheel on my drill. Then finished it up by hand.
gunny
Jan 21 2013, 10:40 AM
Added 2 coats of primer.
gunny
2 Coats of Black
gunny
Jan 21 2013, 10:42 AM
Put on the new rubber from 914Rubber and One less thing on my car that needs to be worked on.
IanS
Jan 21 2013, 10:52 AM
looks great! Never seen one that clean before...
jsayre914
Jan 21 2013, 10:54 AM
Nice Job
Tom_T
Jan 21 2013, 11:06 AM
Looks nice Gunny!
Mikey914
Jan 21 2013, 12:14 PM
Nice job. Mind if I borrow your picture for the website. Unfortunately, I just used my car and didn't have a lot of time to clean it up pretty.
914Eric
Jan 21 2013, 12:21 PM
Very nice job.
OK...I'm a dummy...but where is this access cover? Since I have my car stripped down except for the center console I'm guessing behind the console?
914itis
Jan 21 2013, 12:48 PM
Under the car , covers the steering rack and gas tank access hole.
914Eric
Jan 21 2013, 12:58 PM
QUOTE(914itis @ Jan 21 2013, 10:48 AM)
Ahhh...gas tank access. I took that one off.
Thanks Paul
Tom
Jan 21 2013, 04:46 PM
gunny,
That's nice, until you put it back on and see how much the rest of the undercarriage needs similar work done!.
Don't know when I will get to that! Not sure if I should take the undercoating off?
Tom
gunny
Jan 21 2013, 05:22 PM
I have started on the undercoating already. I'm doing a little at a time. I've already done the driver side front fenderwell and some of the driver floor. It is slow going, Ive been scraping it off with a screwdriver and putty knife. I've been lucky so far and haven't found anything but some small amount of surface rust.
I started the undercoating after completing the interior floor. I removed the tar then painted with por 15. I covered the floor with hushmat before putting the carpet back in.
This is a long term project.
914outlaw
Jan 21 2013, 05:28 PM
QUOTE(gunny @ Jan 21 2013, 11:42 AM)
Looks nice.
Mikey914
Jan 22 2013, 12:32 AM
Looks like you could use at least front trunk drain tube.
Tom
Jan 22 2013, 01:16 AM
Mikey,
Yes,
along with engine bay seals, targa top seals, window seals, the list is long. One of these days I need to get in touch with you and determine all of my needs and get them all at once.
Tom
Mikey914
Jan 22 2013, 11:56 PM
You know I'll just keep making more
But yes, just let me know what you need.
Thx
