battery acid, 2 questions. |
underdog |
Jan 22 2013, 09:24 AM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
Are the pads the battery sits on worthwhile?
Is there a battery that does not emit the bad stuff? Thanks All. |
r_towle |
Jan 22 2013, 10:28 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Annual removal of the battery and washing the entire area with a mix of baking soda and water in a spray bottle, with a rinse of water also does wonders.
Baking soda is a base that counteracts the acid from the batteries and , for me anyways, is a typical annual job...not fun but satisfying to see all the hard work is still clean. I do this to all my lead acid battery cars.... I also touch up any paint issues at the time. You need to remove the computer from its location and twist upside down to get into all the right places. I have added an additional drain tube at the lowest point of the longitudinal with a small pipe welded in to divert any draining around the heater tube abd out below the longitudinal. BUT Paper towels and a good thorough job also works... rich |
rex66m |
Jan 22 2013, 02:44 PM
Member Group: Members Posts: 100 Joined: 3-August 11 From: Birmingham, AL Member No.: 13,393 Region Association: None |
[quote name='r_towle' date='Jan 22 2013, 12:28 PM' post='1807132']
Annual removal of the battery and washing the entire area with a mix of baking soda and water in a spray bottle, with a rinse of water also does wonders. Baking soda is a base that counteracts the acid from the batteries and , for me anyways, is a typical annual job...not fun but satisfying to see all the hard work is still clean. I do this to all my lead acid battery cars.... I also touch up any paint issues at the time. You need to remove the computer from its location and twist upside down to get into all the right places. I have added an additional drain tube at the lowest point of the longitudinal with a small pipe welded in to divert any draining around the heater tube abd out below the longitudinal. BUT Paper towels and a good thorough job also works... rich I need to do this. Is the computer an easy deinstallation? Tks |
Lo-Fi Version | Time is now: 15th May 2024 - 09:42 PM |
