Hydraulic clutch |
Hydraulic clutch |
partwerks |
Jan 22 2013, 10:10 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Has anyone done a hydraulic clutch, and is it hard to do?
Jan 22 2013, 10:48 PM
It has been done. It isn't the easiest thing in the world, but it's not that bad from what I have read.
You can use the pedal cluster and I think the clutch master cylinder from a 964 Carrera. I have read that clearance problems are minimal with that. Then you have to run the hydraulic line somewhere back to the transmission, and you have to fabricate a bracket to hold the slave cylinder. Make sure the bracket is solid; I have read several cases where the slave cylinder moved and made the clutch action very mushy. The sandrail guys may have a good slave cylinder setup. --DD |
David J |
Jan 22 2013, 11:09 PM
Newbie Group: Members Posts: 29 Joined: 18-June 12 From: Dallas Member No.: 14,577 Region Association: Southwest Region |
Search this list for ideas about Hydraulic Clutch setup:
http://www.914world.com/bbs2/index.php?act...aulic+%2Bclutch |
euro911 |
Jan 23 2013, 02:04 AM
Get in touch with Joe O'Brien (Series9) ... I think he was working on a system
sean_v8_914 |
Jan 23 2013, 09:40 AM
964 pedals, tilton has the T/O bearing
Steve |
Jan 23 2013, 12:21 PM
914 Guru Group: Members Posts: 5,590 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Do a search on prs914-6
http://www.914world.com/bbs2/index.php?sho...c=75785&hl= I like Paul's solution the best. The 964 pedals requires hacking up the tunnel, from what I remember. |
RON S. |
Jan 23 2013, 02:59 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Do a search on prs914-6 I like Paul's solution the best. The 964 pedals requires hacking up the tunnel, from what I remember. Steve's right, it will require a hack on a front corner of the tunnel, after that it's a bolt in. Dave's also right that you need a stout bracket on the Trans to hold the slave cylinder. I did it many years ago, and it's still working w/o fail. I ran a hard line through the former clutch cable hole IIRC. You will have to re-route the throttle linkage. Attached thumbnail(s) |
904svo |
Jan 23 2013, 04:26 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Here's a picture of how I mounted my slave cylinder to the transmission.
Lo-Fi Version | Time is now: 21st May 2024 - 03:02 PM |
