weber 44 side drafts |
veedubPORSCHEchris |
Nov 12 2004, 09:00 AM
Newbie Group: Members Posts: 45 Joined: 7-November 04 From: ottawa canada Member No.: 3,070 |
anyone ever put side drafts on a teener?i have access to a set and was thinking on rigging up an intake.
any thoughts on the subject (IMG:style_emoticons/default/huh.gif) cheers chris |
Aaron Cox |
Nov 12 2004, 09:40 AM
44 DCOE's???
most people run webers/dellorto's 40mm-48mm IDF down draft carbs. BTW a friend of mine needs side drafts for his BMW 2002 |
davep |
Nov 12 2004, 09:42 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
That would make for very long intake runners would it not?
Nov 12 2004, 11:11 AM
i was thinking they would come up and face each other on top of the motor so each runner would be no longer then 11inches. can these carbs be converted to idf from dcoe?
SLITS |
Nov 12 2004, 11:15 AM
Thought about it - hooked to the back of a supercharger or turbo.
The idea's ok, but the turn you have to make to the port could result in fuel dropout (poor mixture). If you look at the IDF, IDA setup, it's almost a straight shot to the intake valve. No, they cannot be modified to a downdraft. |
Lo-Fi Version | Time is now: 12th May 2024 - 06:30 AM |
