veedubPORSCHEchris
Nov 12 2004, 09:00 AM
anyone ever put side drafts on a teener?i have access to a set and was thinking on rigging up an intake.
any thoughts on the subject
cheers chris
Aaron Cox
Nov 12 2004, 09:40 AM
44 DCOE's???
most people run webers/dellorto's 40mm-48mm IDF down draft carbs.
BTW a friend of mine needs side drafts for his BMW 2002
davep
Nov 12 2004, 09:42 AM
That would make for very long intake runners would it not?
veedubPORSCHEchris
Nov 12 2004, 11:11 AM
i was thinking they would come up and face each other on top of the motor so each runner would be no longer then 11inches. can these carbs be converted to idf from dcoe?
SLITS
Nov 12 2004, 11:15 AM
Thought about it - hooked to the back of a supercharger or turbo.
The idea's ok, but the turn you have to make to the port could result in fuel dropout (poor mixture). If you look at the IDF, IDA setup, it's almost a straight shot to the intake valve.
No, they cannot be modified to a downdraft.
